Hi, did anyone of you successfully compiled a Qt version > 4.7 on Mini2440? I tried to compile Qt 4.8.3 but with no success... I tried this manual from http://mini2440vietnam.blogspot.de/2011/04/upgrade-qt462-in-mini2440.html that worked perfectly with Qt 4.6. But what do i have to change for higher versions? Thanks and best regards Ozzy
Qt > 4.7 on Mini2440
Hello, try it qt4.8.3: ./configure -embedded arm -release -opensource -silent -qt-libpng -qt-libjpeg -qt-libmng -qt-libtiff -no-multimedia -make libs -nomake tools -nomake examples -nomake docs -nomake demos -qt-kbd-linuxinput -qt-mouse-tslib -xplatform qws/linux-arm-g++ -little-endian -qt-freetype -depths 16,18 -qt-gfx-linuxfb -no-qt3support -no-nis -no-cups -no-iconv -no-dbus -no-openssl -no-fast -no-accessibility -no-scripttools -no-mmx -no-multimedia -svg -no-webkit -no-3dnow -no-sse -no-sse2 -no-gfx-transformed -no-gfx-multiscreen -no-gfx-vnc -no-gfx-qvfb -no-glib -prefix /usr/local/qt-4.8.3-arm -I /usr/local/tslib/include -L /usr/local/tslib/lib (the qt source I have configureed it, only set your compiler and do below) make make install
Hey, thanks for your reply. Did you change anything in the qmake.conf? Or how did you set the compiler? Thanks and best regards Ozzy
