How to boot mini2440 using SD card & network
Sushant Vijay Bhangale
I not able to boot mini2440 using mini2440..
Any one have idea about booting from sd card & network boot.
Thanks..
Juergen Beisert
The S3C2440 SoC cannot boot directly from an SD card. It needs some
firmware to do so. Same for network boot. You need a booloader like u-boot
or barebox in the Mini2440's NAND flash to do so.
ARMbest
For the S3C2440 chips, it can't support boot from the SD card.
But for the Same samsung chips S3C2451, it can support boot from SD card.
Oh by the way
If you use the mini2440 for studying, stick with it, the boot function
don't affect the studying.
But if you use the mini2440 for your project or your products, change it
for the Mini2451, it is Fully compatible with the mini2440 interface, but
support more funciton.
More details for the boot from SD card of mini2451, pleas see the follow
website:
http://armbest.com/Mini2451_User%20Manual.html
