Qt app with touschscreen
Alessandro Manicone
Hi everybody,
I've compiled a simple Qt application (Qt are compiled with corret flag for
using touchscreen in qmake config).
I tried to use qtopia environment changing the etc files to disable qtopia
starting.
I thought that this simple trick would make me able to run my app without
do anything else, but even if the application starts I can't use the
touchscreen.
I thought to some environment variable, because the touch screen kernel
module is up, I tried to export the same qtopia environment but with no
success.
Anyone can help me?
Holger
did you start your application with the options -qws
Take a look at /etc/init.d/rcS
There should be the start of qtopia and there you can start your
application at startup. If you not want to do so, start  it by hand like:
./yourapp -qws &
I hope that helps ;-)
Greetings from Germany
