I was wonder if is there news about WinCE support for Mini2451. Could be used the same Mini2440 BSP?. Or at lest will the Mini2440 drivers will work on Mini2451 too?.
Mini2451 WinCE support.
Yes, you can see the update details and download it from the follow website: http://armbest.com/Mini2451_Update%20news.html
Armbest, the link that you provided is of a page in chinese, and google translate seems not to work ok with it. By guessing where I should do the ckicks, I tried to make the download. The file FriendlyARM-2451-DVD-20131210.7z.002 seems to download truncated. FriendlyARM-2451-DVD-20131210.7z.001 downloads an empty file. Could you provide some advice?. Thanks a lot.
OK, Ferite, Send mail to us to get the download website. We will upload the WinCE BSP and system image for you. You can find our mail on the bottom of the armbest.com website.
Thanks to ARMbest, I could download the BSP. So I copied directories Mini2451 and Mini2451-en to PLATFORM and OSDesigns respectively. I stoped the antivirus, opened the solution (on VS2005 with WinCE R3 installed) and ran Build>Advanced build commands>Sysgen. When the build is performing, there is an error. Here is an extract of the messages: BUILD: [01:0000000114:ERRORE] NMAKE : U1073: don't know how to make 'TargetCompilePass' BUILD: [01:0000000116:ERRORE] NMAKE.EXE TargetCompilePass -i -c BUILDMSG=Stop. BUILDROOT=C:\WINCE600\PLATFORM\Mini2451 NOLINK=1 NOPASS0=1 failed - rc = 2 Has someone experimented this?. I would like to say, on this same environment I have mounted the Mini2440 project and I am able to build it successfully. Thanks.
So by re-installing the BSP (1402) I could built the Image. But now, I realize that this BSP has not GPIO nor ADC drivers. Any boody can help us in a guess of if it is possible to port the 2440 drivers to 2451?. Thanks.
Hello, You can find the official BSP on my website : http://www.domodom.fr/mini2451/WindowsCE6.7z Best regards domodom
Hello, Somebody know how putting mini2451 screen in portrait mode? With mini2441 the regkey 'angle' can be use but it's not working with mini2451. The exe file 'RotateScreen' is ok but It's not persistent. Best regards
Hello ARMbest, is there a BSP for WINCE 5.0 also available? I've quite a complex eVB program based on WINCE 5.0 and don't want to port it to WINCE 6.0. Any chance to get the BSP for WINCE 5.0 (mini2451)?
Hi Domdom, Thanks for the source code you have provided. I created the BSP using the same source code and i deployed the same to my mini 2451 board. It worked fine. However there is one more serious issue with this image. Whenever I restart/reboot the board, it goes to it's original state i.e. deletes all the files and application I had installed. Is there something I am missing. Please help me out on this. Regards, Manoj
