Hi all, I want to connect mini2440 via SSH for remote debugging. I tried to install both openssh4mini2440 and dropbear but had no success. Any tutorial about this topic. I tried -http://code.google.com/p/openssh4mini2440/wiki/HowTo -http://www.friendlyarm.net/forum/topic/2334
SSH on linux
Use my board support package (BSP) for the Mini2440, enable SSH or dropbear in the menu, build the BSP, use it on your Mini2440. It can be very simple...
Thanx for reply. but is it easier to building the bsp then installing any ssh server for a newbie? :)
Most of the time building the BSP works without interaction. At then end you will have a build system, root filesystem, kernel and everything else to make your Mini2440 work in a reliable way. All parts are matching. With this knowledge in background you can start your own experiments adding this, removing that and so on. You don't need to hunt phantom bugs due to inoperative toolchains (wrong architecture support), bad libraries (also wrong architecture), broken buildsystems (not cross build aware) and so on. And if something really bad happens you can recover your Mini2440 from what the BSP provides. When you have learned what is important to get your system work in a reliable way, you can start to cross compile your own projects, because you then know the pitfalls and how to avoid them. Happy hacking
