Hello everyone, I am trying to work with the basic Hello application in Qtopia 2.2.0 I followed the procedure at http://equallybad.blogspot.in/search/label/qtopia and managed to compile arm-Qtopia as well as the Hello application. After sending it to mini2440 using ftp and rebooting its icon appears on the screen. But on clicking the icon, I get the following error. Hello2440 was terminated due to application error (11) I did a lot of google search but could not find a solution. Please help me to get around this. Thanks in advance.
qtopia hello error
Hello, Try to install Qt its best http://qtinstall.blogspot.in/
Hello Sushant, Thanks for the reply. I shall try the procedure given there and reply back. Best regards.
Hello Sushant, I tried the procedure given on your blog and also elsewhere on thenet and finally managed to compile qt using qt-everywhere-opensource-src-4.6.2.tar.gz I also copied tslib and Qt libraries and to the mini2440 Now, if I try ./fluidlauncher or any other demo, I get the error error while loading shared libraries : libz.so.1 Cannot open shared obj file: No such file or directory My linux platform is Fedora 10 and toolchain is aarm-linux-gcc-4.5.1 The file libz.so.1.2.3 and its link libz.so.1 is present on the host under /lib I could not locate libz.so.1.2.3 anywhere under /toolschain/4.5.1/arm-none-linux-gnueabi/lib so that I could copy it to the mini2440 So I am stuck up. Thanks in advance.
