Can anybody help me with getting a usart GPS module working with the Mini4412. I have it connected and when I cat /dev/s3c2410_serial2 I can see gps data, however how do I add this support to the android image (Location support). I read on a forum that I needed to add the following to a /data/local.prop file. However it doesn't appear to work. I had to create the prop file as it wasn't there and I'm not sure its being called. ro.kernel.android.gps=s3c2410_serial2 gps.device=s3c2410_serial2 gps.baud=9600 gps.accuracy=6 I am very disappointed with the Mini4412 board, apart from wifi over the usb I am unable to get Bluetooth and GPS working, you would think these would work by default as it's pretty much a standard with phones and tablet these days. Thanks. Matt
USART GPS Mini4412
Hi Matt, there is a lot with the FriendlyArm boards that don't work. They consider them development boards and not really for commercial use but you are right, they should provide more in the way of firmware if the hardware exists for it. I too have been trying to get Bluetooth working. So far I have not found a suitable dongle for it. GPS would be next but not so needed for this current design. Do you have the Android SDK installed? Can you write Android apps? It might be a good idea to write an app that handles the GPS location and then watch the ADB logcat output for errors etc. If you are able to build the source, you can maybe look into the build and make sure that GPS is being included. I am not familier with the board you are using. I have the Tiny210 and working on adding GPRS support just now.
Hi Dave, Yes I have the build environment setup and I can build android apps. I purchased the Bluetooth module for the tiny210 hoping that I could get the differences from the tiny build scripts and incorporate them into the tiny4412. I think the issue with that is the tiny4412 is using android 4.2.1 which no longer uses bluez. http://www.at91sam.org/Tiny210-S5PV210.html I can get you the vid and pid of the module I purchased, it might be cheaper than paying for the "official" one. There are a few boards with GPS examples so I'm in the process of getting the conf files and moving them over to the tiny4412 project. I went for the tiny4412 because it had a quad core and a newer version of android, I am starting to wish I had gone with the tiny210, there appears to be much more support for it. I'm building a image as I write and will hopefully test it this evening. I will let you know how it goes. I would love to grab the 4.3 / 4.4 source tree and see if I could get it running on the board , but I think that is optimistic until I can get something simple working. Thanks Matt
pretty sure that the serial ports on android on 3.xx or higher kernels for samsung chips is ttySACx (x being the number of the port you want to use).
As for it being a standard on all phones and tablets these days, it's not :-) A lot of devices have some hinky adapter that you have to buy. I agree that bluetooth should work but bluetooth on android isn't the same as bluetooth on linux, the same as ethernet too. I've had bluetooth working on a mini210s, it was a cheap one I bought from poundland (it was £1!!), I was trying to use a bluetooth keyboard, which you'd expect to just work but no, you have to BUY a piece of software that acts as some kind of bridge to the OS to allow you to use your own keyboard. This has nothing to do with friendlyarm and everything to do with android. Another for instance, the only reason we got ethernet on the mini210 to work PROPERLY was because of the x86-android ethernet patches (I'd been asking for this functionality for some time), which is nothing to do with friendlyarm nor is it a true part of android either!! Also, friendlyarm aren't releasing production images, these are merely to get people started, they are pretty impressive as they stand but the clue is in the title, development board.
Hi Reggie, ttySACx is mapped to /dev/s3c2410_serialx I believe it's a symlink. I understand these are development boards and I appreciate your comments.
I'll have to have a look later on, something else to remember is that these boards were also initially designed for an asian market, they didn't really care much about the google aspect of it because they have their own homegrown alternatives for email, app stores etc. so until we inform them of issues that affect our normal use, they'll never know that things need looking at/fixing :-) Things like ethernet, gprs? etc. work on the chinese images because they specifically don't use the android apis, so it's likely that anything that we don't have right now will need to be added either by us or friendlyarm or it could be that they don't even have hooks into the google apis (like ethernet!). Also, I'd forgotten I'd been looking into serial a little bit over the last couple of days, is serial even a proper 'thing' on android? clearly you/we are all able to get data to and from the mini boards running android but that's kernel stuff and debug messaging, which !same as serial on linux. From what I've read, you need a rooted device and serial-api from google code? I'll try and look into this over the next few days (I get a feeling I'm going to have to), I'll also see if I can get some information off to friendlyarm about it.
Hi Reggie, I appreciate any help with this I can get. looking at other devices, there is a gps.conf , gps.xml and a gpsd service within the manta folder, they reference serial1 at 115200 but this appears to be for a "bcm475x" gps. I have a generic NMEA UART module. I can definitely see gps data when I open up the serial port but the android OS doesn't appear to see anything. Thanks Matt
Well, this will be exactly what I'm talking about, as far as I know serial isn't much of a thing to android, if there's no calls in teh api, then android may not see it. https://code.google.com/p/android-serialport-api/
Oh for the good old days when GPS apps use to just access the serial port. But obviously this method was no good because all the other apps couldn't use the GPS data at the same time, how would we check in on facebook while we are using the sat nav.
Looking around and you can get apps such as :- https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&frm=1&... which will allow you to use a USB GPS receiver connected via prolific 2303. I understand that you can get a sdk for the prolific to read the device. Not an ideal solution but it might work. Shame I can't do something similar with Bluetooth.
Did you get any help from Corewind? They are in internal China dealer who improperly advertise as an international supplier (with a pile of URLs linked to their sites). No support or warranty outside the mainland. Check the dealer lists on http://www.arm9.net/agent.asp
Hi Matt, Interestingly I just connected a Xbee module to CON2 on my Mini210 board and the Logcat is showing a GPS parse error. Are you able to get a serial output GPS module as it looks like if you connect this to CON2 you should get GPS data. @Reggie. The SerialPort API that's on the internet works well with Android.
I wonder if we ask nicely whether friendlyarm would consider putting the serial-API onboard as a feature for us? It's in their interests to push forwards any kind of development work like this.
I can receive GPS data using a serial console such as the one built into the image (test program). I have to change the permissions on the tty dev port before I can open it using a pc with telnet access. But the port does open and you can clearly see the GPS data. However this is a far cry from getting Android to see the GPS data. The USB GPS receiver and program to inject gps data onto android works fine, but its far from perfect as it means running another app and enabling one of the developer options to simulate location data.
I did try an contact corewind but as I didn't buy the board from them they where less than helpful, pretty much stating that you didn't buy the board from us as we don't supply to the uk so go away. I think the issue with these boards are that nobody really takes ownership and as such can't offer any support. I did purchase 2 USB dongles from corewind , as I was hoping that these would be supported but I paid £15 pound each for the dongles and then around £15 for import. the dongles aren't anything special and look very similar to one I got from ebay for around £2.00
My idea of a development board is very different to friendly arm. I purchased a keil cortex m4 board, it has everything you could want on board along with a shed loads of examples with great documentation. The android boards are very different, lots of GPIOS and serial ports on the hardware but missing the basics in my opinion. Sure there is a bit of a tutorial on how to build Android and I have managed to do it, but if you want to do anything else your down to hunting the internet. In my opinion you would be better saving your money and getting a beagle board, the support looks much better with a much larger community. I'm sure I will receive some flames for this, but it is just my opinion. I think most people buy a development board so they can learn and play, but I personally feel the resources to learn and play are missing. Maybe I just haven't found them....
Hi Matt, Considering the issues I have with the FA boards I have (except the Tiny210 CAP as this has been running faultlessly for over a year now and is on 24/7) I've switched to Olimex boards for Android. Although the source was lacking to start with I am a few others have managed to get them working with a custom Android build of 4.2.2 After a few months work I now have a capactitive LCD working along with a RTC, GPRS modem and 6 serial ports and GPIO. They also have a battery charger built in so this makes them far more usable out of the box, so to speak. The good thing with their boards is that they are in Europe so less issues to deal with in regards to translated manuals. Their Forum is also pretty good. They are also open source, both hardware and software and you can even purchase the CPU's from them. Try getting any of the Samsung processors used in the FA boards :) It's a real pity about the FA issues as Andahammer in the USA has been great support to me, even though I only ordered a few boards to try and develop with them.
I read the entire thread, Seems no one got a solution... Any chance to make Android see the GPS data??
