Hi, I'm using S700 LCD & Capacitive Touchscreen bundle along with Tiny210V2 module. Under normal usage the touchscreen works quite well, though whenever I push the screen a little harder with my finger, touch screen gets locked under the point of pressure with random but slight movements. The interesting part is that touch functionality remains suspended even after resetting the board! The only way to get it working again is to turn the board off and switch it back on, say cut the power and put it back. Is it only me experiencing this issue?! Or is there something really wrong?! :-?
S700 Touchscreen Suspends Under Pressure
Hi, Good issue, it can be solvable.... Doubts: 1.Let me know, is ur application layer is android and kernel is linux? 2.if so, when ur pressing the touch screen harder with ur finger...check /proc/interrupts...whether u are come across interrupts are not....? 3. Let me know, the touch screen completely locked or the portion where u had touched.....? Thanks, Srikanth.
We have met this issue. We bought over 10 pieces, all failed at this issue. We have called and emailed this issue to FriendlyARm. No response yet. The Touch Screen model is S701.
