Hi, I'm trying to use ubuntu on a mini6410 board, the images available on the CDs are compiled with a70 configuration, my LCD is a s70 and when i try to compile the kernel source with mini6410_s70_config i get an error saying that TASK_INTERRUPT is not defined, that occurs when compiling the drives of buttons and touchscreen, and when i try to use the image available on the CDs and which is compiled with an a70 configuration file, i don't manage to calibrate my screen, so any help about this issue will be very appreciated. Thanks in advance.
why doesn't ubuntu source have a mni6410_s70 config file
I have the same problem. Where can I download atleast any precompiled images for S70 - AT070TN94 for WINCE, LINUX or other OS ?
well, i think if you're trying to run ubuntu or linux, you can just use the linux kernel with ubuntu filesystem and it will work. In the CDs, linux image is created by compiling kernel 2.6.28.6 while ubuntu image is created by compiling 2.6.38, the kernel source folder for ubuntu doesn't have any config file for s70 but linux kernel source does. so just use 2.6.28.6 with your config for s70 and it'll work (hopefully). for WINCE, sorry I have no idea, and i don't know if it does need a config file, as far as i know, these file are for OSs that will compile from source, that mus not be the case for windows, for android may be but windows i don't think so. I hope my answer was clear enough, and helpful.
