Hi everyone! I am playing with, how they call it, "PWM" example but it is not a real PWM. There is no width modulation, only modulation with frequency. With this PWM you cannot change effective value at output. Is there any example or anything (maybe kernel module) what is a real PWM? Thanks in advance
Real PWM?
You can look at this http://www.youtube.com/watch?v=9y6kIe9jpu8
If you want real PWM, you need to build your own driver. On the S3C2440 datasheet PWM function can be implemented by using the TCMPBn. PWM frequency is determined by TCNTBn. For a higher PWM value, decrease the TCMPBn value. For a lower PWM value, increase the TCMPBn value. You can study the mini2440_pwm.c source code in the kernel build.You can see that it only control the frequency. clk_p = clk_get(NULL, "pclk"); pclk = clk_get_rate(clk_p); tcnt = (pclk/50/16)/freq; __raw_writel(tcnt, S3C2410_TCNTB(0)); __raw_writel(tcnt/2, S3C2410_TCMPB(0));
You can try to change __raw_writel(tcnt/2, S3C2410_TCMPB(0)); to __raw_writel(tcnt/4, S3C2410_TCMPB(0)); rebuild it and you will get 1/4 PWM.
