I'm trying to get ubuntu on my tiny210v2 SBC and I downloaded all the ubuntu files from the FTP server. There is no zImage file there, even though the readme says that there should be. Can someone at friendlyarm please put the zImage for ubuntu 12.04 on the FTP?
Ubuntu on tiny210v2
hi WalterW, do you still have the problem or you make it works? can you help me? i have the same problem! thank you
Hi uleman, Yes I'm still having the same problem. From some posts that I have read it looks like you don't use a nand rootfs but run the ubuntu files FROM the SD card. Of course I haven't found any step-by-step instructions yet...
I've been searching in this forum and found this topic: http://www.friendlyarm.net/forum/topic/4922 take a look WalterW!
Thanks, nice! I got some more info from there..however the armworks.cc link doesn't work so I can't get to the tutorial that reggie keeps talking about :(
Thanks Reggie! I'm going to start the job now and i hope to put my tiny210v2 on fire with ubuntu. see you...
FriendlyArm have provided an ubuntu image and tools on the ftp site, it works with the rootfs via an ext4 partition on an SD card. == Things you will need == * Ubuntu downloads from the friendlyArm ftp site so you have the desktop or server rootfs archive. * mktools from one of the dvd images * mini210S * serial console access to the mini (for giggles) * network connection * 4GB micro SD card, already fused with SD-Flasher.exe and an ext4 partition added to it, doesn't matter too much how big the fat partition is, just make sure the ext4 partition is a couple of GB. == Make sure you've got superboot on the SD card == If you haven't burnt superboot.bin to your SD card, [http://armworks.cc/index.php?title=Mini210S_Burn_rootfs_to_Nand#Burning_... follow the section in this link for information on how to do that] and remember to backup the SD card before you start as it will destroy all of your data. For the ext4 partition you will need to use a disk resizing app. like gparted on a linux machine. When you open gparted and look at your SD card, you'll notice that there is 151MB of unallocated space, this is where superboot is, so don't touch it, it's supposed to be there!! In gparted, resize the fat partition that you made, it doesn't matter too much how big it is, I made mine 512MB so I can mess with other stuff on the card at a later date, using gparted, I had to click on the green tick to actually resize the fat partition before it would let me partition the rest of the sd card. Once you've resized the fat partition, you can format the unallocated space that is freed up by the resizing, it's easiest to just right click on the unallocated space to the right of the fat partition, choose new partition and then set the filesystem to ext4, click add and then click the green tick to execute the changes. That's it for the SD card, you can now move onto the next sections. == Unpack and prepare your Image == First off we need to unpack our rootfs archive, I'll be using the ubuntu-desktop-1204_20120628.tgz file, open a command prompt browse to wherever you downloaded the rootfs and the images_18714.rar files to and do: sudo tar -xvzf ubuntu-desktop-1204_20120628.tgz That will keep the permissions intact, and unpack the archive into a folder called ubuntu-desktop, now we need to copy them to the ext4 partition, so put your uSD card in a reader and plug it into your PC, you will need to know the path to the ext4 partition on your SD card. sudo cp -varP ubuntu-desktop/* <path to ext4 partition> It will take a while, once it's finished, Next you'll need to unpack the the images folder and copy that to your fat partition on the sd card, so do: rar x images_18714.rar cp -varP images/ <path to fat partition> == Edit all of the things == Next you'll need to edit a couple of files, otherwise you won't be able to sudo from the serial console and you'll miss out on all the universe repo goodies!! you'll need root privs. to open these files, from the ext4 partition, edit /etc/sudoers, scroll down to line 19 and add a line to make it look like this: # User privilege specification root ALL=(ALL:ALL) ALL fa ALL=(ALL:ALL) ALL Save and exit the file. fa is the username and password to logon to the system (I think!! there might be others, it auto logs you in and serial console won't let you use root!!) so adding it to sudoers gives us root privs when we need them. Next we need to edit /etc/apt/sources.list, scroll down to line 15, we're going to uncomment the 4 deb/deb-src lines, this will give us access to all the useful universal tools from the ubuntu repos, so uncomment the lines so it looks like this: ## Uncomment the following two lines to add software from the 'universe' ## repository. ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu ## team. Also, please note that software in universe WILL NOT receive any ## review or updates from the Ubuntu security team. deb http://ports.ubuntu.com/ubuntu-ports/ precise universe deb-src http://ports.ubuntu.com/ubuntu-ports/ precise universe deb http://ports.ubuntu.com/ubuntu-ports/ precise-updates universe deb-src http://ports.ubuntu.com/ubuntu-ports/ precise-updates universe Once you've saved and exited we need to edit a file on the fat partition, in /images/ you'll find a file called FriendlyARM.ini, open it in your favourite editor, you should be ok with the defaults but I like to change the StatusType to the following: StatusType = LED I hate it when the mini210S screams at me when *it* did something wrong. == Burn the kernel then run Ubuntu == Now that you've prepared the card you can safely remove it from your system and plug it into your mini210S, we're going to burn the kernel and superboot to nand, so flip your bootmode switch to SD and power on the mini210S, in about 10seconds it should be all over and you should be ready to boot. Once it's finished burning the kernel, flip the bootmode switch back to nand, and toggle the power switch, that's pretty much it, if you have a serial console connected to con1 then you should see the usual junk flying past your screen and you will be presented with a login prompt at the serial console, on screen (mine is a H43 lcd) you should see the ubuntu desktop, as I mentioned, it automatically logs you into the desktop (unity sucks on a 4.3" screen), the touchscreen afaik isn't setup (or at least not enough to work but it did seem to be detected at least) so you'll want a usb hub, mouse and keyboard. From the serial console I would suggest doing sudo apt-get update and then you can go and hunt down any of your favourite apps and install them. That's about it, have fun! == Issues == You will see 3 errors at least on your travels : mountall: Event failed init: Failed to create pty - disabling logging for job implemented sudo: unable to resolve host localhost.localdomain mountall probably gimps out because something it wants doesn't exist, no idea what though, failed to create pty is alledgedly to do with something that, again, doesn't exist when init starts logging and sudo is a host thing, just needs setting accordingly somewhere. If anyone fixes these issues before i do, post the fix here!! For the touch screen, you'll probably want to apt-get install libts, and probably the x11 stuff for it too, you'll also probably need /etc/friendlyarm-ts-input.conf from maybe the linux 2.6.35 image, and etc/ts.conf(should be installed with libts I think but it'll need to be edited to look like the one in linux image) == update == After translating the ubuntu readme, it seems that there are a number of other issues, touchscreen is not supported (yet) and the multimedia system (hardware codecs etc.) are all turned off! There is a fix for the pty issue and it's pretty simple too, from a command prompt on the mini210S, do: wget https://launchpad.net/ubuntu/+source/upstart/1.5-0ubuntu8/+build/3710339... --no-check-certificate dpkg -i upstart_1.5-0ubuntu8_armhf.deb
Ok, weird problem...my tiny210v2SDK just continually beeps if I try the SD card now. However it boots up to the previous image fine if I select NAND BOOT.
I also get no serial output when I boot from SD, NAND is fine. My SD card is layout is as follows: |----------------------| |(Superboot) 151MB | | | |----------------------| | | |FAT 256MB | | | | | |images/ | | |Superboot.bin | | |Friendlyarm.ini | | |Linux/ | | |zImage | | | |----------------------| | | |(RootFS) EXT4 3.6GB | | | |----------------------| Are there any changes need to the friendlyarm.ini file? You tutorial didn't mention any, but several posts have OS= Ubuntu so I was curious.
Ok, I'm getting closer. I wiped my 4GB SDcard created a partition then I let SDflasher relayout the card. That gave me this: |----------------------| |(Superboot) 151MB | | | |----------------------| | | |FAT 3.6GB | |----------------------| Then I copied the images folder from the DVD onto the card and made sure that the tiny210 would boot/install. After I verified that it worked I used gparted on my Ubuntu machine to resize the FAT partition to 512MB and create the ext4 partition. |----------------------| |(Superboot) 151MB | | | |----------------------| | | |FAT 1.6GB | (Found out that 256MB wasn't enough to hold | | | the DVD images folder. So I made it 1.6GB) | | | | |images/ | | |Superboot.bin | | |Friendlyarm.ini | | |Linux/ | | |zImage | | | |----------------------| | | |(RootFS) EXT4 2.0GB | | | |----------------------| Then, as your tutorial says I copied from the ubuntu-dekstop folder over the ext4. I had to mount it first though 'sudo mount -t ext4 /dev/mmcblk0p2 /media/ubuntu' (note: create /media/ubuntu folder before mounting) Everything works except now I get the following on my console and the tiny210 keeps rebooting....ideas??? [ 3.152199] Freeing init memory: 1428K [ 3.180788] EXT4-fs (mmcblk0p2): recovery complete [ 3.180846] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: /init: line 103: can't open /r/dev/console: no such file [ 3.201739] Kernel panic - not syncing: Attempted to kill init! [ 3.201795] Backtrace: [ 3.201843] [<c0171efc>] (dump_backtrace+0x0/0x110) from [<c059bb04>] (dump_stack+0x18/0x1c) [ 3.201915] r6:cfc24000 r5:c074d798 r4:c074bff4 r3:00000000 [ 3.201980] [<c059baec>] (dump_stack+0x0/0x1c) from [<c059bb7c>] (panic+0x74/0xf0) [ 3.209423] [<c059bb08>] (panic+0x0/0xf0) from [<c019980c>] (do_exit+0x74/0x5f4) [ 3.216777] r3:c074d798 r2:00000000 r1:00000024 r0:c06b1297 [ 3.222392] [<c0199798>] (do_exit+0x0/0x5f4) from [<c019a070>] (do_group_exit+0x98/0xc8) [ 3.230460] r7:000000f8 [ 3.232976] [<c0199fd8>] (do_group_exit+0x0/0xc8) from [<c019a0b8>] (sys_exit_group+0x18/0x20) [ 3.241553] r7:000000f8 r6:00000001 r5:bed50ef4 r4:00000004 [ 3.247175] [<c019a0a0>] (sys_exit_group+0x0/0x20) from [<c016dfc0>] (ret_fast_syscall+0x0/0x30) [ 3.255943] Rebooting in 5 seconds.. [ 8.328432] Restarting Linux versRunning OS 'LINUX' Loading kernel... file: /images/Linux/zImage: 3 MB(4045356 Byte)
Thanks Reggie...but it turned out to be my fault, sort of. For some reason the copy command didn't copy all of the files to the ext4 partition. The console file was actually missing! I didn't have a Linux machine handy to look at it when I posted or I might have saved myself some trouble.
which console file? if you mean /dev/console, that's a device node :D although strictly speaking, everything in linux is a file, but /r/dev/console is the device node inside the cpio file, which usually breaks when you start doing 'normal' command lines. if you're copying a rootfs across to an SD card, or any other hdd/usb storage medium, you need to do it as root otherwise all of the important stuff (like device nodes) won't get copied across, as non-root users can't create device nodes.
So, Here I am in 2016, trying to do this, and of course, the Internet landscape has moved. armworks.cc is no-more, and FriendlyARM no longer provide an FTP site. Where can I get ubuntu-desktop-1204_20120628.tgz (or server) from? Where can I get images_18714.rar ? I think thats all I need.
