Hello All! Sorry about my ignorance, but I´m a newbie. I have one Mini2440 with W35 3.5" original LCD which works just fine. I bought a new S70 7" thinking that would be just plugging the new and it will work fine, but it is not. The 7" gets all white with two thick grey bars in the middle after some line movements at boot. There is a drive, a configuration or something? Reading several threads looks like is something complex. Replacing a 3.5" for a 7" is really so difficult or there is some kind of tutorial somewhere? Thank you in advance. JR
How to replace a 3.5" LCD by a 7" on Mini2440?
Hi Joao, You'll have to add your screen characteristics in the BSP file (mach-mini2440). This screen is not actually supported in the factory linux kernel.
Thank you for the reply Screwface! I think in the datasheet of the display I have the characteristics. Where exactly I find this file in the Mini 2440?
According to this the A70: http://search.gmane.org/?query=a70&group=gmane.comp.embedded.ptxdist... is in the Pengutronix BSP. Maybe, that helps. http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html
You're right Dave, A70 is in Pengutronix BSP, but I'm not sure timings are the same than S70. Joao, the file is in arch/arm/s3c2440 folder of your linux kernel. But I won't be able to help you to calculate the values as I don't know how they are calculated. I also tried to change the mini2440 screen for a bigger one but I was stuck at that level, and I have no time at the moment to spend on this topic. :(
http://article.gmane.org/gmane.comp.embedded.ptxdist.oselas.community/17... "The original Tiny6410 implementation targets S70 screen which uses 1-wire but also has additional buttons (I just remember the one for orientation)." Do the mini2440 and mini6410 use the same LCD controller?
Mini2440 and Mini6410 share the same LCD connector. But due to the nature of their different SoCs, the LCD controller inside the SoC differs. But at the electrical level of the LCD signals this doesn't matter. You just need to set up their controllers differently to output the same signals and timings.
Still no luck! I´m accessing the Mini2440 via Telnet. I found no arch/arm/ folder. I´m not a Linux user, so I looked everywhere and found nothing. Any other suggestions?
arch/arm will be on your host computer, where you placed the kernel source prior to cross-compiling.
No, I just bought this Mini2440 with a 3.5" display which came working out of the box with Qtopia. So I bought one 7" LCD display thinking that would be just unplug the smaller and install the 7". But did not work at all. I´m unable to solve this problem even searching in the forums. So I bought a new one, already with a 7" LCD, but unluckily came in separated boxes and without compatible configuration too! Now I have two Mini 2440, two 7" LCD display and both just works with the 3.5! The name is FriendlyARM, but looks like it is not so friendly at all, since for a simple task which should be exchange a display, looks like you have to be a savvy user to compile a kernel! And I´m not finding any solution even looking in several forums. Any thoughts?
Embedded devices are not like desktop PCs. Your expectation is wrong. Your embedded toy isn't a multi giga herz giga byte machine. Its much smaller in many ways and needs more love to make it work in a way you like it. The software cannot detect the attached display (like a desktop PC can). So its up to you to tell the software what you intend to connect. Welcome to the world of embedded programming.
Juergen, I know that, but when you buy a system, like this new 7" Mini 2440, it should come working just like my old 3.5" came. If someone just want to start playing with FriendlyARM, getting started having to compile a kernel for adjust the LCD timing should not be the first experience. And if even in this forum looks like is not a easy task, what to say for a newbie? But if this is my fault or from the vendor, is not the point. If someone could try any suggestion will be welcome.
> If someone could try any suggestion will be welcome. Keep your fingers on the software. If you intend to do serious things with your new toys you must first create a reliable build environment. Otherwise you will end up hunting phantoms when your own programs are crashing and you will be *really* frustrated.
We're also a random collection of people across the net who might or might not have answers for you, the simple fact is that all of us at one point or another have had to deal with our own newbie-ness and learn.
Well, this is not meant to be a toy. I was thinking in using it to be a touch interface with a pre loaded remote control QT application which sends control strings over serial and controls my stuff. I bought the 3.5" which came working out of the box. The programmer just uploaded the software via ftp to my unit and worked perfect. But I think the 3.5 " LCD is too small for my eyes and fingers. So I bought one 7" LCD which did not work, and after search everywhere, I was not able even to find a meaningful tutorial for this supposed simple exchange. I´m too busy dealing with other problems and I thought this forum could be of some help. But looks like everyone have to learn by themselves. Eventually, I one masters in this stuff, he come back here make fun of who does not. I contact at least 5 people who have this ARMs and nobody knows how to deal with this display stuff. If who use can´t, what to say form a ex newbie. I will ebay this UNFriendlyARMs and replace by PC based tablet which I can deal myself without bothering the "experts". Thank you very much.
Hey, I think there is a simple solution: just set up your system like described here: http://mini2440vietnam.blogspot.de/2011/01/install-linux-into-mini2440-b... The only thing you have to change is not to use the "zImage_T35" but the A70 image from the CD or from the friendly-arm download. I tried this manual and got the same display results as you did, and after some searching I found the hint with the wrong display-image. After that everything worked fine. Best regards Ozzy
I get a little tired of people demanding that we help them and then complaining when we do, there is of course the company that the product was purchased from if all else fails but that seems not to be an option these days. If you can't do the simple things, like compile a kernel with the correct driver or read various tutorials on the net on how friendlyarm boards work, then you're not going to get very far anyway. The lcd's used to be controlled by a commandline option called mini2440=, and also selecting the correct lcd in the menuconfig. Drivers > Graphics Support > Support for frame buffer devices > LCD Select. From there you can actually select the lcd you want, they're all in there.
Sorry to bring up this discussion. at first i also get this problem. but after some checking, the zImage for 7 inch LCD is included on the shipped DVD. or you can download it at http://www.arm9.net/download.asp i already tried it, and it works like a charm Well
