Hi friends, I'm trying to rebuild Linux from scratch for FriendlyARM mini6410, and I noticed that every time i try to build the image it keeps asking me for configuration even with the presence of the .config file in the right place, the command i use to rebuild the image is : make ARCH=arm CROSS_COMPILE=arm-linux- zImage then instead of compiling the sources i see what seems to be the configuration menu which appears after taping : make config and then that gets me another configuration file which is not the one i'm hoping to use. My question is : is this scenario normal? if no what am i doing wrong or how can i avoid it ? Thanks in advance
kernel configuration
Where did this .config file comes from? If it was copied from somewhere, run "make ARCH=arm oldconfig" to make it valid.
At the start of a compiling session I just export the PATH, ARCH and CROSS_COMPILE vars: export PATH=/path/to/compiler/bin:$PATH export ARCH=arm export CROSS_COMPILE=arm-linux- then just rename the .config file and put it in the arch/arm/configs directory (something like mini6410_defconfig) then instead of copying stuff or running oldconfig you can just do: make mini6410_defconfig make and it will pick up your settings correctly from the env vars.
Thanks Reggie that worked. But i still have another question if you don't mind of course, do you happen to know any version of kernel and rtlinux patch that can work on mini6410, i spend a lot of time trying to find one but i still have trouble compiling the kernel after applying the patch, i tried the kernel 3.0 with patch for mini6410 and rt patch proposed by timesys for that matter (here's the link http://repository.timesys.com/buildsources/k/kernel/kernel-3.0/ ) but it always gives me some compilation errors i guess it's because of the changes made by the patch. So i am wondering if you have any suggestions. Thanks
