Hi All, i am using tiny 6410 i have compiled TS with QT when i run ./fluidlauncher -qws i can see gui on touch screen but i am not able to use touce for input. i am getting following errors Couldnt load module friendlyarm-ts-input No raw modules loaded. QWSTslibMouseHandlerPrivate: ts_config() failed with error: 'No such file or dir ectory' Please check your tslib installation! i am using following 1) -qt-mouse-tslib while configuring 2) in cd/etc vi profile export LD_LIBRARY_PATH=/usr/local/tslib/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/dev/input/ts-if export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/dev/touchscreen-1wire export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 3)$cd /etc/init.d/ $vi rcS #bin/qtopia& #echo" "> /dev/tty1 #echo"Starting Qtopia, please waiting..." > /dev/tty1
tiny 6410 not able to use touch
In cd/etc vi profile I have already compiled tslib. but touch is not working .. now i am using follwing and no error is there but still touch screen is not working. export LD_LIBRARY_PATH=/usr/local/Trolltech/QtEmbedded-4.7.0-arm/lib:/usr/local/tslib/l ib export QPEDIR=/usr/local/Trolltech/QtEmbedded-4.7.0-arm export QTDIR=/usr/local/Trolltech/QtEmbedded-4.7.0-arm export QWS_MOUSE_PROTO=/usr/local/tslib:/dev/input/event0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/dev/touchscreen-1wire export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 if there is anyone who is able to use touch screen i request you to share following files profile rcS ts.conf suggest some way to proceed .. struggling here from 3 days
