hi, I have mini6410(WinCE6.0) + LCD2VGA converter. I have used 18.5" LCD monitor in my application. I have encountered a problem that, the screen goes blank. It neither shows any signal error. I have checked connections and seems ok. also restarted the mini6410 board via reset key, but still problem remains as it is. BUT after power off and again power on the complete system, I will get everything working fine. What should be the issue? Help me resolve this problem. Thanks in advance.
LCD gets blank
Hi, Issue is with Power related. Inrush current causes the device LCD Screen blank. explain me? At what state, did u came across the issue? So, that i can suggest u the solution. Thanks, Srikanth.
