hi All , i need some source code example for using timers on tiny 6410 or mini6410. thanks Sudhanshu
how to use timer tiny 6410 /miny 6410
Hi Juergen, i am new with linux and friendly arm, please provide some link or source code example for the same. thanks Sudhanshu
Once again: What is wrong with the HRT API the kernel provides to you? Why you do need access to the hardware instead?
Hi Juergen, i have no problem in using that as well. can you please provide some sample code or some web link for that.? THanks Sudhanshu
My question was meant to get an idea what you want to do. Just doing some things in userspace periodically could be done with the help of the generic POSIX timer API. But maybe you want to control a motor or something else, then this API is not enough and you also need real-time support in the kernel. Otherwise search the web for timer_create(), timer_settime(), setitimer() and friends. A nice source how to deal with periodic jobs in a real-time Linux environment is the small tool 'cyclictest'.
Hi all, thanks juergen for your guidence.. i have done some google using below code i can use timer with accuracy 1 sec.. but not less than that.. i have worked on embedded c till date.. lil new to linux.. i am expecting time which i can use even for 1 millisecond... do you have some sample code for same #include <stdio.h> #include <signal.h> #include <sys/time.h> #define INTERVAL 5 int howmany = 0; void alarm_wakeup (int i) { struct itimerval tout_val; signal(SIGALRM,alarm_wakeup); howmany += INTERVAL; printf("\n%d sec up partner, Wakeup!!!\n",howmany); tout_val.it_interval.tv_sec = 0; tout_val.it_interval.tv_usec = 0; tout_val.it_value.tv_sec = INTERVAL; tout_val.it_value.tv_usec = 0; setitimer(ITIMER_REAL, &tout_val,0); } void exit_func (int i) { signal(SIGINT,exit_func); printf("\nBye Bye!!!\n"); exit(0); } int main () { struct itimerval tout_val; tout_val.it_interval.tv_sec = 0; tout_val.it_interval.tv_usec = 0; tout_val.it_value.tv_sec = INTERVAL; tout_val.it_value.tv_usec = 0; setitimer(ITIMER_REAL, &tout_val,0); signal(SIGALRM,alarm_wakeup); /* set the Alarm signal capture */ signal(SIGINT,exit_func); while (1) { //printf("!"); } return 0; }
