Hi, As we see some of the simple example of mini2440 which are there in cd. Also I saw some program executable files in usr/bin of above program which I run using ./file command it work properly. I had ubantu 10.10 ver linux os installed in pc. I took .c files of examples in cd and compile it in linux gcc compiler in my system, I got executable file in system. Then I transfer these files to usr/bin of kit using serial port. I check it in directory.Then I am trying to run these files using ./file command but it shows message Permission denied. Please suggest what I suppose to do?
how to run executable files on mini2440
You should start by reading how Linux manages execution permissions (read the manual page of the 'chmod' command for example)
