Do not start the mini2440 board on nor
sushant
In mini2440 Have a problem i am inserted the u-boot,zImage & roofs..
the nor memory is selected but is show on hyperterminal is single dot
and nand is not shoe the output
How have you set up Hyperterminal?
Why are you not using DNW?
Are you using the proper RS232 cable between your host and the target?
It might be easier for someone to help if you state which tutorial or HowTo
you are using to get started.
sushant
Check using DNW & Hyperterminal same error..
**** SHOW ***
***** NOT SHOW ******
here the options not available for NOR mode.
[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[a] Absolute User Application
[n] Download Nboot for WinCE
[l] Download WinCE boot-logo
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
Well, that sort of answers my first question.  You could still be setting
both of them up incorrectly.
Right cable, ie the one supplied for the purpose?
Referencing a help sheet so we have some idea of each step that you are
performing is going to cut down the number of postings.
Smith
Proper rs232cable  connected host & target..
I solve this problem ...
