How to add library to mini2440
srinivas
Hi all,
my project required libjpeg.so.62 library in mini2440. so anyone tell me
about process of adding library to mini2440.
Thank you...
Raj
Hi Srinivas,
You just cross compile your required library on linux platform and copy the
binary into lib folder on arm board
srinivas
Thank you raj for your reply...
I downloaded library source jpegsrc.v9.tar.gz and cross compiled for arm as
shown below
./configure --host=arm-linux CC=arm-linux-gcc
make CC=arm-linux-gcc ARCH=arm
it is compiled successfully, in .libs folder i got libjpeg.so.9.0.0 and
then copied to my mjpg-streamer folder in board. when i run script i got
libjpeg.so.62 no such file or directory..what is the problem?????
Juergen Beisert
> what is the problem
You must also cross compile your mjpg-streamer and link it against your
libjpeg. Applications and libraries must be consistent.
