I am trying to use the RS485 port on the Real6410 board. I assume this is device ttySAC3. I can read from this port just fine but I can't write anything. Anybody know what is going on here?
RS485 on Real6410
I guess my question is "Does the driver that ships with the Real6410 board have the ability to automatically toggle the pin that controls the RS485 transmitter?" If so, how do I configure the port to do this? If it doesn't, how do I control this pin?
Real6510 is a clone of the FriendlyARM designs? If it is the usual Samsung reference design, the UART does not have CTS/RTS enables during standard serial, only in MODEM mode (Unfortunately it is the way Samsung UARTs are made). You need to have a driver that uses a GPIO pin to turn RS485 on/off, or check the schematic and see if there is a direction detect circuit on 485 chip's direction lines that sniffs the Tx line from the UART. These devices aplenty fast to do direction control in your code by directly manipulating a GPIO pin to control direction. Just have a simple function to turn transmit on or off. Turn it on, send data, turn it off and listen. Even with an app written in Python under Debian on a 2440 you can do it in a few microseconds.
