Hi, I have 3 custom images: u-boot (u-boot.bin) kernel (uImage) rootfs {rootfs.jffs2} I need to burn them into NAND using superboot on mini2440. I have created this tree on SD card: images images/FriendlyARM.ini images/superboot-20101223.bin images/linux/uImage images/linux/rootfs.jffs2 and edited FriendlyARM.ini to this content: #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action=install OS=linux VerifyNandWrite=Yes StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = linux/u-boot.bin Linux-Kernel = linux/uImage Linux-CommandLine = noinitrd init=/linuxrc rootfstype=jffs2 root=/dev/mtdblock3 console=ttySAC0 mini2440=0 Linux-RootFs-InstallImage = linux/rootfs.jffs2 Linux-RootFs-RunImage = linux/rootfs.jffs2 when I commend out Linux-RootFs-InstallImage parameter, superboot will flash u-boot and I am able to boot with it, but no kernel and root filesystem is flashed. When Linux-RootFs-InstallImage parameter is active, superboot will give error flashing yaffs2 image. Is there any way to flash jffs2 image and kernel image into flash using superboot? I know I can flash u-boot, boot into u-boot console, create partitions and flash images, but I like automated way which comes with superboot. Thanks for any info, Best regards
burn jffs2 image to flash using superboot2440
Any luck on this? I am having a similar issue to you. I am using the newest mini2440 OEM which now requirs the Superboot v1.0 to load image. OS = CE. I can get the image to load and initially boot but seems to "disappear" after reboot of the 2440. Almost as if it loaded to sdram and not flashed. Also, Are you familiar with the "# user BIN part" image option? I get an error in term server as follows: Superboot V1.0(20130514) for Mini2440 by FriendlyARM Try to find SD card.... Found. not support Action 'INSTALL' with OS 'BIN' I have built a couple hundred of these using the old superVIVI bios method, now I am scrambling to get some info on the new load. I don't want to JTAG these as well if possible. Thanks in advanced Mike
Similar to mihalko, I can install a bootloader (barebox in my case) and superboot says the kernel installed successfully, but my root image is jffs2, and superboot seems to expect yaffs2. However, while superboot says the kernel installed, when I try booting from nand I get an error: booting kernel of type uimage from /dev/nand0.kernel.bb Bad Magic Number My FriendlyARM.ini: #This line cannot be removed. by FriendlyARM(www.arm9.net) USBMode=No Action=Install OS=Linux VerifyNandWrite=Yes LowFormat=No Status Type = Beeper| LED Linux-BootLoader=linux/barebox Linux-Kernel=linux/uImage Linux-CommandLine=noinitrd rootfstype=jffs2 root=/dev/mtdblock3 console=ttySAC0 mini2440= Linux-RootFs-InstallImage=linux/root.jffs2 The SD card looks like: /images/friendlyARM.ini /images/linux/barebox /images/linux/uImage /images/linux/root.jffs2 The superboot output: Try to find SD card... Found. Installing OS 'LINUX' Installing bootloader... Installing bootloader succeed Installing bootloader succeed Installing kernel... Installing kernel succeed Installing yaffs2-image... Installing yaffs2-image failed The bootloader, kernel and rootfs are the ones I've been flashing on all previous supervivi boards through DNW. What've I missed with the kernel installation? Can I install a jffs2 image? Is there any documentation on superboot and the friendlyARM.ini?
TheRegnirps: yes, this is the way I am doing it right now, the only way I was able to burn system on mini2440. Flash u-boot from SD card using superboot as I wrote in first message and than flash kernel and jffs2 image from SD card. But it seems to be lot faster to flast these images directly using superboot, so that is why this thread comes to place.
