Hi every body. I try to developed mini6410 with No OS, but i have a problem with booting from SDRAM. I believe at power on reset the hardware will copy 4KB of NAND flash to its STEPPING-STON (locate in 0x0C000000) and the code will Pursue from address 0x0C000000. In these case i developed a code to copy whole of the NAND flash to the SDRAM(locate in 0x50000000) but i can't direct Program-Counter to the SDRAM to run my program. however i'm sure my code has written in SDRAM address (0x50000000). in additional my RO compiler setting (linker options) set to 0x50000000. i really thankful if some one help me.
