I'm using PTXdist 2012.12 with a Mini2440. I initialize and kick the
watchdog from my Qt application. It used to work fine with kernel 2.6.38
but now with kernel 3.7 I get the following error:
watchdog watchdog0: watchdog did not stop!
This is the code I use to initialize and kick the dog:
// Watchdog constructor
cWatchdog::cWatchdog(cSystem *fSystem)
WatchDogTimeout = 30;
System = fSystem;
QObject::connect(this, SIGNAL(signalAddStatusText(QString)),
System->GUI->StatusDialog, SLOT(AddStatusText(QString)));
emit signalAddStatusText("Watchdog initialization");
// Try and get a handle to the watchdog
WatchdogHandle = open("/dev/watchdog", O_WRONLY);
// If the handle is not valid
if (WatchdogHandle < 0)
perror("Could not get a handle to watchdog");
return;
// Set the watchdog timeout
ioctl(WatchdogHandle, WDIOC_SETTIMEOUT, &WatchDogTimeout);
emit signalAddStatusText("Watchdog timeout set to 30sec");
// Kick the dog
KickTheDog();
// Kicks the watchdog (wakey, wakey)
void cWatchdog::KickTheDog(void)
// Kick the dog
write(WatchdogHandle, "V", 1);
