My PTXdist 2012.12 is working fine but when I try and compile a Qt app there are several libraries missing (libQtGui, libts, etc.) I looked in: /OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysroot-target/lib And found that most of the libraries required by Qt are missing. All my boxes are checked in ptxconfig (See attached ptxconfig). My qmake.conf is also pointing to the correct paths: QMAKE_INCDIR = /home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysro ot-target/include /home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysro ot-target/usr/include QMAKE_LIBDIR = /home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysro ot-target/lib /home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysro ot-target/usr/lib How can I get PTXdist to compile these libs?
PTXDist 2012.12 libs not compiling
maybe .... http://www.friendlyarm.net/forum/topic/4853
Hi Dave, Thanks for the reply. My problem is slightly different. Ruben has all the libraries, I don't have the required libraries in: /OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysroot-target/lib I first need to get my libraries compiled into this path. Quite interesting to see so many guys using this in SA. @Ruben and Sean: I'm based in JHB, maybe we can have a beer sometime? Cheers
Thanks, did a diff and all seems in order. Maybe the PTX guys can give their input. I do not want to clean my PTX at this stage, maybe there is a quicker solution.
Did you also took a look into "OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sysroot-target /usr/lib"? I tried it here and there are all required Qt libs present.
Ok, resolved it: QMAKE_LFLAGS = -L/home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sys root-target/lib -L/home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-mini2440/sys root-target/usr/lib
