No boot menu
bluscape
We recently received a batch of FriendlyARM Mini2440's. They do not have a
normal boot menu and is executing test code on startup:
Superboot-2440 V1.1(20130529) by FriendlyARM
Try to find SD card...... not found.
Hello USB Loop
How do I get the standard boot menu to load my own bootloader?
Thank you
Gautam
Hi bluscape,
Did you check the Boot Switch? Make sure it is in NOR boot mode. You can
then load your bootloader in NOR flash.
Gautam
Robinson
Hi, follow these steps:
1. H-JTAG download
   http://www.friendlyarm.net/dl.php?file=hjtag-100.zip
2. connected via the parallel port of your PC, the mini2440.
3. Download This PDF, where are the instructions
   http://www.friendlyarm.net/dl.php?file=download.pdf
4. Download the file .bin, u-boot + Survivor, supervivi64.bin
   http://www.mediafire.com/download/r8p9mius21kghdf/supervivi64.rar
The same thing happened to me, but I already solved.
Regards
bluscape
Thanks Robinson. Solved my problem.
