Hi, I have tested my friendlyarm mini2440 using mjpg streamer to http://192.168.1.230:8080/?action=stream both connected to my wifi router using ethernet cable,it is working fine. But when i enter the same ip address in my other laptop which connected wireless to same router..it cant detect the ip..so anyone help me how can i design a livevideo transmission on web so that i can see the video on web anywhere...my english is bad..sorry for that..please mail me the tutorial to k.sundeep2007@gmail.com..i hope everyone understood my idea..if not reply i will try to explain clearly
how to see the live video on web using mjpgstreamer anywhere?
Hi, You'll have to create a NAT rule in your router to redirect the external IP:port address to the internal IP:port of your mini2440. That way, when you'll try to access your router with it's external IP, it will redirect the flow to your mini on the LAN.
Hi screwface, I am sorry i could not understand the suggestion...i am using a D-Link wifi router..with a local(airtel broadband connection)..how can i a write a NAT rule?pls help me..
Hi sundeep, I don't know why you can't access the mini from your second laptop connected by wireless to the same router. First I would try to ping the mini from your second PC ans see if the mini is reacheable or not. I would also try to ping another PC from the wireless to see if this wireless PC is able to communicate on the network or not. The main principle is: your Access Point has to IP address. One is the internal IP address looking like 192.168.xxx.xxx and the other one is the external IP address seen from the world wide web. If you try to access the mini from the web, you can't use the mini LAN address (192.168.xxx.xxx) as it is not known. You have to use your AP external address instead. But once your AP receives the request, it can not handle it. It has to redirect it to the mini on the internal network. That's why your AP must contain a NAT rule to do it. I am not very familiar with routers. But I think your D-Link router has a yellow RJ45 plug connected to your AP. So I would look at this AP for the NAT rule.
