Hi all, I have arm-linux-gcc cross compiler and common-android-3.4 kernel.By using this source i compiled for arm target as follows pc@pc-desktop:~/data/android/common-android-3.4$ export PATH=$PATH:/home/pc/data/arm/source/opt/FriendlyARM/toolschain/4.4.3/bin/ pc@pc-desktop:~/data/android/common-android-3.4$ echo $PATH home/pc/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/u sr/bin:/sbin:/bin:/usr/games:/home/pc/data/arm/source/opt/FriendlyARM/toolschain /4.4.3/bin/:/home/pc/data/arm/source/o pt/FriendlyARM/toolschain/4.4.3/bin/ pc@pc-desktop:~/data/android/common-android-3.4$ make ARCH=arm CHK include/linux/version.h CHK include/generated/utsrelease.h HOSTCC scripts/basic/fixdep make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s GEN include/generated/bounds.h CC arch/arm/kernel/asm-offsets.s . . . . drivers/misc/akm8975.c:35:32: error: linux/earlysuspend.h: No such file or directory drivers/misc/akm8975.c:537: error: 'THIS_MODULE' undeclared here (not in a function) drivers/misc/akm8975.c:540: error: unknown field 'ioctl' specified in initializer drivers/misc/akm8975.c:540: warning: initialization from incompatible pointer type drivers/misc/akm8975.c:547: error: unknown field 'ioctl' specified in initializer drivers/misc/akm8975.c:547: warning: initialization from incompatible pointer type drivers/misc/akm8975.c:699: warning: data definition has no type or storage class drivers/misc/akm8975.c:699: warning: type defaults to 'int' in declaration of 'MODULE_DEVICE_TABLE' drivers/misc/akm8975.c:699: warning: parameter names (without types) in function declaration drivers/misc/akm8975.c:730: error: expected declaration specifiers or '...' before string constant drivers/misc/akm8975.c:730: warning: data definition has no type or storage class drivers/misc/akm8975.c:730: warning: type defaults to 'int' in declaration of 'MODULE_AUTHOR' drivers/misc/akm8975.c:730: warning: function declaration isn't a prototype drivers/misc/akm8975.c:731: error: expected declaration specifiers or '...' before string constant drivers/misc/akm8975.c:731: warning: data definition has no type or storage class drivers/misc/akm8975.c:731: warning: type defaults to 'int' in declaration of 'MODULE_DESCRIPTION' drivers/misc/akm8975.c:731: warning: function declaration isn't a prototype drivers/misc/akm8975.c:732: error: expected declaration specifiers or '...' before string constant drivers/misc/akm8975.c:732: warning: data definition has no type or storage class drivers/misc/akm8975.c:732: warning: type defaults to 'int' in declaration of 'MODULE_LICENSE' drivers/misc/akm8975.c:732: warning: function declaration isn't a prototype drivers/misc/akm8975.c:732: warning: type defaults to 'int' in declaration of 'MODULE_LICENSE' drivers/misc/akm8975.c:732: warning: function declaration isn't a prototype make[2]: *** [drivers/misc/akm8975.o] Error 1 make[1]: *** [drivers/misc] Error 2 make: *** [drivers] Error 2 please help me regarding this error
error in android kernel compilation for arm
you need to export $CROSS_COMPILE= to whatever the prefix for the compiler is, so if it's arm-linux-gcc then it would be: export $CROSS_COMPILE=arm-linux-
drivers/misc/akm8975.c:35:32: error: linux/earlysuspend.h: No such file or directory i searched in the source file there is no earlysuspend.h file in common-android-3.4 source[inckude/linux/ earlysuspend.h. please help me regarding this error ??
