arm-linux-gcc
Panda
I'm very new in Linux. I download arm-linux-gcc-4.3.2.tgz after extract
"tar xvzf arm-linux-gcc-4.4.3.tgz –C" and set to path "export PATH=$PATH:
/opt/FriendlyARM/toolschain/4.4.3/bin" everything is fine but will try
"arm-linux-gcc -v" I see this error
"/opt/FriendlyARM/toolschain/4.5.1/bin//arm-linux-gcc: line 1: syntax
error: unexpected "(" "
How Can I do fix this error
sean_h
Hi
$PATH from the shell will possibly indicate where your problem is.
Panda
Dear Sean_H
I install  arm-linux-gcc on my Friendly Arm Board.
Juergen Beisert
The compiler you have intalled is a so called "cross compiler". It must be
installed on your host, not your target.
Panda
Dear Juergen Beisert,
Thank you for reply, I install gcc on host after compile code. Thanks
