Hi every body...i have mini6410 with 4.3 inch LCD
I tried to initialize display controller in bare metal mode.
the problem is the LCD driver can't find true data on memory and the
display shows dummy image. I think the configuration is incorrect...
my LCD_initialize is:
#define WIND0_BUFFER 0x52000000
#define LCD_WIDTH 640
#define LCD_HEIGHT 480
#define VSPW 96
#define VBPD 46
#define VFPD 20
#define HSPW 2
#define HBPD 11
#define HFPD 31
void LCD_Init(void)
int i,j;
Pnt=(short*)WIND0_BUFFER;
GPECON = 1;
GPEDAT = 1;
GPICON = 0xAAAAAAAA;
GPIPUD = 0x00000000;
GPJCON = 0x00AAAAAA;
GPJPUD = 0x00000000;
SPCON = (SPCON & 0xFFFFFFFC)|0x1;
MIFPCON = (MIFPCON & 0xFFFFFFF7);
S3C6410_DISP_CONT->VIDCON0 = (0<<29)|(0<<27)|(0<<26)|(0<<18)|
(0<<17)|(0<<16)|(9<<6)|(0<<5)|(1<<4)|(0<<3)|(0<<2)|(0<<0);
S3C6410_DISP_CONT->VIDCON1 = (0<<7);
S3C6410_DISP_CONT->VIDTCON0 = (VBPD<<16)|(VFPD<<8)|(VSPW);
S3C6410_DISP_CONT->VIDTCON1 = (HBPD<<16)|(HFPD<<8)|(HSPW);
S3C6410_DISP_CONT->VIDTCON2 = ((LCD_HEIGHT-1) << 11) | (LCD_WIDTH-1);
S3C6410_DISP_CONT->WINCON1 = (5<<2);
S3C6410_DISP_CONT->VIDOSD1A = 0x00000000;
S3C6410_DISP_CONT->VIDOSD1B = (LCD_WIDTH << 11) | (LCD_HEIGHT);
S3C6410_DISP_CONT->VIDOSD1C = (LCD_WIDTH*LCD_HEIGHT);
S3C6410_DISP_CONT->VIDW01ADD0B0 = WIND0_BUFFER;
S3C6410_DISP_CONT->VIDW01ADD1B0 = WIND0_BUFFER + ( LCD_HEIGHT*LCD_WIDTH
S3C6410_DISP_CONT->VIDW01ADD2 = ((LCD_WIDTH*2) << 0);
S3C6410_DISP_CONT->VIDCON0 = (S3C6410_DISP_CONT->VIDCON0 & 0xFFFFFFFF) |
(3<<0);
S3C6410_DISP_CONT->WINCON1 = (S3C6410_DISP_CONT->WINCON0 & 0xFFFFFFFF) |
(1<<0) | (1<<18);
for(j=0;j<(LCD_HEIGHT*LCD_WIDTH);j++)
*Pnt++=0x00;
In addition my compiler is code warrior v1.4
Thank you...it's urgent for me to get respond.
LCD configuration help
What do you mean by dummy image? You code fills the whole LCD with black. Try filling the LCD with a RGB pattern. Therefore you can find out whether the windows base addr is wrong or the pixel format is wrong.
thanks for reply but I did this before and it was't change...I loaded a RGB pattern on DRAM...but half of screen is black with many parallel and colorful lines. even I have changed my defines but the LCD wasn't in my control...
