I have wireless RF Transceiver Module 433Mhz CC1101 with spi interface. How use this module with tiny6410? Please help me!
tiny6410 spi
I tried to do the following with kernel linux-2.6.38:
in kernel config enable:
Device Drivers\SPI support\Samsung S3c64XX series type SPI
Device Drivers\SPI support\User mode SPI device driver support
in:
arch/arm/mach-s3c64xx/Kconfig
add:(otherwise dev-spi.c don`t compiling)
config S3C64XX_DEV_SPI
bool
default y
help
Setup spi bus.
in:
arch/arm/mach-s3c64xx/mach-mini6410.c
add:
#include <plat/s3c64xx-spi.h>
#include <linux/spi/spi.h>
static void mini6410_set_cs(unsigned line, int cs) {
unsigned int pin;
int change = 1;
switch (line)
case 0:
pin = S3C64XX_GPC(7);
break;
default:
printk(KERN_ERR "mini6410_set_cs, unknown line %d\n",
line);
change = 0;
break;
if(change)
//gpio_request(pin, "temporary");
gpio_set_value(pin, cs);
//gpio_free(pin);
static int cc1101_ioSetup(struct spi_device *spi)
printk(KERN_INFO "cc1101: setup gpio pins CS and External Int\n");
s3c_gpio_setpull(S3C64XX_GPL(8), S3C_GPIO_PULL_UP);
s3c_gpio_cfgpin(S3C64XX_GPL(8), S3C_GPIO_SFN(3));
s3c_gpio_setpull(S3C64XX_GPC(7), S3C_GPIO_PULL_NONE);
s3c_gpio_cfgpin(S3C64XX_GPC(7), S3C_GPIO_OUTPUT);
return 0;
static struct s3c64xx_spi_csinfo cc1101_cs_info[] = {
.fb_delay = 0x3, // 9ns feedback delay for cs line
.line = 0,
.set_level = mini6410_set_cs,
struct cc1101_platform_data {
int (*board_specific_setup)(struct spi_device *spi);
static struct cc1101_platform_data cc1101_info = {
.board_specific_setup = cc1101_ioSetup,
static struct spi_board_info mini6410_spi_board_info[] __initdata = {
.modalias = "cc1101",
.platform_data = &cc1101_info,
.controller_data = &cc1101_cs_info,
.max_speed_hz = 2*1000*1000,
.irq = IRQ_EINT(16),
.chip_select = 0,
.bus_num = 1,
.mode = SPI_MODE_0,
in:
"static struct platform_device *mini6410_devices[] __initdata = {"
add:
&s3c64xx_device_spi1,
in:
"static void __init mini6410_machine_init(void)"
add:
printk(KERN_INFO "MINI6410: SPI ID %i\n",
spi_register_board_info(mini6410_spi_board_info,
ARRAY_SIZE(mini6410_spi_board_info)));
s3c64xx_spi_set_info(1,0,1);
After running system I get:
user@fa:~$ dmesg | grep spi
spi-bus: source is mout_epll (0), rate is 24000000
user@fa:~$ dmesg | grep SPI
MINI6410: SPI ID 0
user@fa:~$ find /sys -name '*spi*'
/sys/devices/platform/s3c64xx-spi.1
/sys/devices/platform/s3c64xx-spi.1/spi_master
/sys/devices/platform/s3c64xx-spi.1/spi_master/spi1
/sys/devices/platform/s3c64xx-spi.1/spi1.0
/sys/bus/platform/devices/s3c64xx-spi.1
/sys/bus/platform/drivers/s3c64xx-spi
/sys/bus/platform/drivers/s3c64xx-spi/s3c64xx-spi.1
/sys/bus/spi
/sys/bus/spi/devices/spi1.0
/sys/bus/spi/drivers/spidev
/sys/class/spi_master
/sys/class/spi_master/spi1
/sys/class/spidev
/sys/module/spidev
But in /dev nothing with spi
Somebody, please help.
For the mini2440 I also made this change in my kernel config:
Device Drivers
-> SPI support
SPI Master Controller Drivers
-> Samsung S3C24XX series SPI
SPI Protocol Masters
-> User mode SPI device driver support
Do you need to do something similar for the mini6410?
Thanks for the reply, but i already done this: I enable in kernel config: Device Drivers\SPI support\Samsung S3c64XX series type SPI Device Drivers\SPI support\User mode SPI device driver support. You talk about it?
Sorry, I have no specific experience on the mini6410. With help I wrote a SPI driver for the mini2440, however you appear to have more experience than I do. Another idea: I thought udev made the /dev/spi* nodes from information in /sys/class/ Good luck.
Sorry, I did not notice that you had already done the kernel modification :( Google for <udev spi> I am trying to find which udev file it is suppose to be in.
Well, I can't find anything in my /lib/udev/rules.d files with spi* in it. Does dmesg have anything to say?
I found it very similar to what we need. I can check tomorrow. http://blog.csdn.net/zhanglongtumi/article/details/9049077
Good. One last one : https://www.kernel.org/doc/Documentation/spi/spidev Device creation Driver binding Good night.
