App over ethernet
Justin
Is there a way to load my apk to several tiny210's over ethernet? I will be
installing 30 of these next week and want to be able to load all of them
with my app via ethernet.
Reggie
if you have access to the apk via a hyperlink then you should be able to
load it through a browser.
Reggie
wow, I need to wake up a bit, if you have access to the apk via the
internet then you should be able to load it from a web browser.
TheFwGuy
I use Dropbox or as Reggie mentioned, if you have a server you can load the
apk there and access it via a browser on the Tiny210.
Reggie
he's using gingerbread, it actually fails to download anything, complains
about no usb storage (the way the unit is setup there is no sd card access,
no usb access, no serial access, no wifi, this is by design).
There is plenty of space left on the device but it seems that there is no
user download area if you don't have an sd card in.
Anousha khan
Hi, anyone  please help me in configuring Ethernet with mini 210 android
4.0.3, i have done all the ip and proxy settings, the same settings  run
internet in my pc but not in the mini 210 kit.
After all  the settings it shows a red cross on the two computers seen in
the right bottom corner.is there a problem in the hardware side?? but even
the green and the yellow lights are showing a yes signal. I am confused
Anousha
Reggie
you need the latest version, android ICS does not have ethernet support at
all, anything that works works by mistake not by design on it.
The latest friendlyarm version has been patched for ethernet.
Reggie
and it's android, not linux, so it doesn't work in the same way.
Dave McLaughlin
I've given up on the Wired Ethernet connection. It is just not reliable
enough and as Reggie states, is not part of ICS anyway.
I suggest you use the WiFi connection instead as this works very well on
the Tiny210. I have a system running 24/7 and it has not once lost
connection of stopped working. Far more reliable than the 6410 running
Gingerbread was.
Anousha khan
Thanks Reggie and Dave, but i have to use the ethernet port in the long run
as my app demands it, now can you please tell me the latest version as i am
using this one
http://www.minidevs.com/Mini210-S5PV210.html
and specifically how the new hardware is different from the old one from
ethernet perspective,as i have to design my own android board with ethernet
port working on it.
Anousha
ZEAxm
should work, I have a RT-RoIP2 Radio over IP Gateway for tiny210v2.
everything works through the ethernet port.
I later try to understand how it is implemented.
ZEAxm
описана
реализация,
но я слаб в
английском
ZEAxm
written what to do, but I do not quite understand English
Arousha Khan
Thanks ZEAxm,
I have another problem as well,I have just purchased a tiny 4412 kit , I
have to use its Ethernet on android platform but in its setting the
Ethernet turning on  option is  a label only its not turning off or on,
more over even by-passing this issue I entered my IP addresses in Ethernet
configuration option it said please reboot the board to apply settings, I
rebooted several times but of no use, please send me  those image files
which allows Ethernet to turn on or that android version for tiny 4412 in
which I can configure and use Ethernet(currently it has Android 4.2 by
default)
