PTXdist ha a BSP project for mini2440, which comes with linux 3.7 and qt 4.8.3. However since qt 5.1.0 is out, I created a simple patch to build qt5 in PTXdist. The functionalities: 1. Build qmake on the host 2. Targetinstall libs, plugins and fonts to the rootfs Known issues: 1. sysroot-cross/bin/qmake is affected by qt.conf which is created by host-qt4, be sure to rename or move this file. 2. rules/qt5.in does not provide configure options for qt with GUI. All options must be done in rules/qt5.make Improvements to qt4: 1. qt5 supports a new configure option - hostprefix, with which the build for host qmake and target libraries can be done in one makefile. No host-qt5 is required. (host-qt4 exists to build qmake-cross on the host) To use the patch 1. Down and the zip from https://docs.google.com/file/d/0B6xn0R6QR_RzcXVxMnNvY3N5Rkk/edit?usp=sha... 2. Put qt5.in and qt5.make to rules 3. Put qt-everywhere-opensource-src-5.1.0 in your PTXdist patches folder 4. Rename or move sysroot-cross/bin/qt.conf 5. Enable qt5 in ptxdist menuconfig 6. $ptxdist go 7. Use sysroot-cross/bin/qmake to build you Qt5 application! <http://clarkli86.blogspot.com.au/2013/08/build-qt510-for-mini2440-with-p...;
Build qt5.1.0 for mini2440 with PTXdist
Hello Clarkli, I´ve tried to access the tutorial on your blog but with no success. Please, where can I find the complete step by step? Many thanks,
