Hello.... I want to compile a dynamic module (Hello world) in linux on mini2440. Can any one help me to sort out this.
How to Compile a dynamic module in linux on mini2440
You need the sources and the configuration of the binary kernel you currently run on your Mini2440. Its build system only needs a valid ARM toolchain. Everything else happens automagically. Build this kernel and then build your module against this already built kernel out of tree. Refer in-kernel documentation in "Documentation/kbuild/modules.txt" Happy hacking
