Hello Friends. When i will connect 3 devices only 2 devices are working. The third device is not viewed. Thanks friends, Gabriel Bonato
3 devices on usb hub are not working (tiny210v2)
The connection problem happen sometimes.You disconnect the connection and then try.The 3 devices are connect.
There is a known bug with the USB hub on the Tiny SDK boards. It is a WinCE problem in the original BSP from Samsung. If the USB devices are not connected to the hub at boot time, the hub is never recognized. If some devices are present all are usually recognized, but the source of the problem is not known and Samsung has never produced an update. I avoid CE and use Debian with Python.
