Attaching Jlink-JTAG with FriendlyARM Mini2440(ARM9) ,QtCreator
Ravi Kumar
 I have Jlink-JTAG with serial no:058006790, and trying to connect to
FriendlyARM Mini 2440(pic attached) using Qt creator....i have worked all
the commands in the manuals but not succeded..required help..
                          My Initial configurations...on Board
          1) Setup up the GDBserver compiled for arm-linux and place in
home folder of the board..
         2) Running the following commands from the folder
              >[root@FriendlyARM gdbserver]# ./gdbserver :2331 /home/ggg
 (here ggg is the simple GUI program created in qtcreator and cross compile
for arm-linux)
                     Process /home/ggg created; pid = 712
                     Listening on port 2331
 On Host Machine(UBUNTU 12.04)..
   1) Started ./StartJLinkGDBServer.sh ...JTAG Connected
   2) Started qtcreator with the same program running on the board,in
release board..
   3) Then in tools->options->Debugger->GDB-> in GDB Startup Script placed
the file "JLinkGDBServer.ini" provided by segger
   4) In qtcreator, Debug->Start Debugging->Start and Attach to remote
application ..Settings are as per
   5) After presseing the ok buttion...the qt creator shows Debugging
starts(Picture 4)..
   6) But in the Jlink-GDBServer (Picture 5) shows starting the CPU and
then it holds on ...nothing happens
   7) If i press the Debug interrupt buttion in qtcreator the output of
Jlink-GDB Server will close with Segmenation Fault
               ...What is the problem..is it with board or my
settings..please suggest me ..worked more than a week to get upto hear....i
want actually debug qt creator codes..please help me..waiting for your
precious reply...pls guide me for exact settings
