Dear friendlyarm users I'm using mini6410 in carpc system. It is located in car which is not accessible after installation. So we can not turn it off/on manually and it should go low power modes automatically. we use COM1,2 ports in our project, it is possible to use data serial port as an event for low power mode. I mean for example when we don't receive any data from serial port for 20 minutes Mini6410 should go low power mode and as soon as any data receive from serial port it should go to normal mode. Would you mind please tell me how we can run this feature in this unit? Regards,
low power mode in mini6410
As I have no specific experience on the uP used in the 6410 I can only suggest a general method. The UART will have interrupts that can signal when there is information in the RX (receive) buffer (Receive buffer data ready?). Maybe, there is some way you can wake the uP out of sleep mode using a RX interrupt. What does the datasheet have to say about power management on the uP used in the mini6410? For the S3C2440 (mini2440) it talks about: **** The wakeup from SLEEP mode can be issued by the EINT[15:0] or by RTC alarm interrupt. Signaling EINT[15:0] for Wakeup The S3C2440A can be woken up from SLEEP mode only if the following conditions are met. a) Level signals (H or L) or edge signals (rising, falling or both) are asserted on EINTn input pin. b) The EINTn pin has to be configured as EINT in the GPIO control register. c) nBATT_FLT pin has to be H level. It is important to configure the EINTn in the GPIO control register as an external interrupt pins, considering the condition a) above. Just after the wake-up, the corresponding EINTn pin will not be used for wakeup. This means that the pin can be used as an external interrupt request pin again. **** I don't see a process for waking up from sleep on UART interrupts. Maybe you could wake up from sleep by changing a port as in a) when you get RX data in your software. Just some thoughts.
