Hi, I have a problem with a new mini2440 S3C2440 ARM9 Board with 3.5" TFT LCD Touch Screen. It appears almost completely white when I turn on the device! If I tilt the screen, I can see a faint image of bootloader and Qutopia interface. Touch functions all work ok, I can launch apps, etc. Here is the pictures of what it looks like: http://www.badscience.ru/images/4.jpg http://www.badscience.ru/images/3.jpg I only attached a screen and power adapter, didn't change anything at all. I also checked all LCD connections and didn't find any problems. Is it some configuration must be done? I didn't find anything about such behavior in manual.
LCD screen turns white
So, it's definitely a hardware problem, am I correct? I don't see any broken wires or some other damaged components.
May be due to poor contact of the connector. Try unplug the LCD connector and then reconnect. Good luck to you.
Thanks for your answers! Connectors and cables look good to me, but I'll try to get another cable for a test.
I head the same problem. The power cords ware 1m long and very thin, so the voltage drop at 1A was more than 1V! So even when power supply was giving 5V the voltage at the board was 4V witch is not enough.
Quite sure it's connector, sometimes happens with me, worse when I move the board. If I dont touch it, stays on for hours.
When I finally figured out the right DC power connector to buy I found that I had to buy two different manufacturers representations of the mechanical dimensions in order to get one type that would not be intermittent.
Hello! Anyone solve the problem? I've got 5 Mini boards and white-screen problem appears on each one. Sometimes screen goes white after 2-3 days sometimes is a couple of minutes. There are two ways to fix it - turn off the board or disconnect LCD cable, but it's very irritating. Can I do anything else? best regards Tom
We have a similar problem with our product. When we set date and time to our unit, the screen goes to white and remains there until u touch it. The application behind it is still running. Is there any help any one can provide here? Thank you. Tejas.
The reason for white screen is when the CPU is powered up it by default configures all the GPIO as output ports and makes them high. The LCD backlight control (PWR_EN) in the schematics is pulled high and since the LCD is also not initialized you will see either random lines or a totally white screen depending on the LCD you have. We fixed by inverting the PWR_EN signal on the LCD board and by modifying the kernel ( mach_mini2440.c file ) so instead of making the GPIO high on initialization we explicitly pull it to ground. We did this for the N43i board and it works as described. --fatbrain
fatbrain, I can see how you wouldn't want this unwanted feature in a consumer's product. So, thanks for explaining how you sorted the problem. However, one question. Your procedure takes care of the initialisation process, but don't you have to do something for future accesses to the backlight? IE, invert all backlight commands? Dave
yes , you need to invert backlight commands for future accesses via command line. Through code you could initialize GPIO for inverted logic, so your code does not change and the only changes are done in GPIO init. --fatbrain
fatbrain, "Through code you could initialize GPIO for inverted logic" Not having run across this capability on the ATMEL AVR series, that I have been working with for the past 10 years nor aware of being able to do this on the S3C24XX series I did some investigation. The Samsung datasheet does not appear to mention this capability. Also, looking at how one can operate GPIO from userspace I haven't seen anything which indicates that you can invert the logic. Could you point me to some documentation or describe in some more detail how one can do this without modifying legacy code? Regards, Dave
I have written wrapper code over sysfs for accessing GPIO , and the wrapper code takes care of inverted logic.
calibration of touch screen in friendly arm mini 2440 w35 board getting disturbed everytime the board is switched on. i m recalibrating it but no effect. Please suggest some measures. Thank You
After you have calibrated the screen you should find a /etc/pointercal file. When you turn it off does it disappear? If it does, show me your /etc/init.d/rcS file
