Hi I downloaded latest Mini2440-CE6-Suite-1115.exe and tried to build runtime image of Mini2440 and Mini2440-en in VisualStudio. In both cases image build failed as shown in attached BUILDerrors.docx. Can someone guide me where I have gone wrong.
Building WinCE image
Hi I downloaded latest Mini2440-CE6-Suite-1115.exe and tried to build runtime image of Mini2440 and Mini2440-en in VisualStudio. In both cases image build failed as shown below. Can someone guide me where I have gone wrong. BUILD: [01:0000000155:PROGC ] Compiling .\global.c BUILD: [01:0000000158:ERRORE] C:\WINCE600\PLATFORM\COMMON\SRC\COMMON\CACHE\.\global.c : fatal error C1033: cannot open program database '' BUILD: [01:0000000159:PROGC ] Compiling .\ioctl.c BUILD: [01:0000000162:ERRORE] C:\WINCE600\PLATFORM\COMMON\SRC\COMMON\CACHE\.\ioctl.c : fatal error C1033: cannot open program database '' BUILD: [00:0000000163:PROGC ] Files Warnings Errors BUILD: [00:0000000164:PROGC ] Midl 0 0 0 BUILD: [00:0000000165:PROGC ] Message 0 0 0 BUILD: [00:0000000166:PROGC ] Precomp Header 0 0 0 BUILD: [00:0000000167:PROGC ] Resource 0 0 0 BUILD: [00:0000000168:PROGC ] MASM 0 0 0 BUILD: [00:0000000169:PROGC ] SHASM 0 0 0 BUILD: [00:0000000170:PROGC ] ARMASM 0 0 0 BUILD: [00:0000000171:PROGC ] MIPSASM 0 0 0 BUILD: [00:0000000172:PROGC ] C++ 0 0 0 BUILD: [00:0000000173:PROGC ] C 2 0 2 BUILD: [00:0000000174:PROGC ] Static Libraries 0 0 0 BUILD: [00:0000000175:PROGC ] Exe's 0 0 0 BUILD: [00:0000000176:PROGC ] Dll's 0 0 0 BUILD: [00:0000000177:PROGC ] Preprocess deffile 0 0 0 BUILD: [00:0000000178:PROGC ] Resx 0 0 0 BUILD: [00:0000000179:PROGC ] CSharp Compile 0 0 0 BUILD: [00:0000000180:PROGC ] Other 0 1 1 BUILD: [00:0000000181:PROGC ] BUILD: [00:0000000182:PROGC ] Total 2 1 3 BUILD: [00:0000000183:PROGC ] BUILD: [00:0000000184:PROGC ] 1 Warnings, 3 Errors BUILD: [00:0000000185:PROGC ] GetSystemTimes (seconds): Idle: 53 Kernel: 71 User: 5 BUILD: [00:0000000186:PROGC ] Elapsed time (seconds): 38 Build for Windows CE (Release 601) (Built on Aug 17 2006 15:18:52) File names: Build.log Build.wrn Build.err Build.dat \WINCE600\build.err
Do you have a Virus scanner running? Try to trun it off until the build is done, also you should open the \WINCE600\build.err instead of the VS log
