Hi I have a Tiny210SDK CAP7 board with installed the latest image of Android (4.0.3). I have problems to have the board seen by ADB under Linux when connected to the USB port. Something is recognized but ADB returns always ????????? for the device. I tried many different settings of udev and other Android terminals are always recognized. So the first question is ... am I the only one who experience this problem or somebody else hit this obstacle too ? I need to know if I'm chasing a real problem or maybe I have just a bad board. Thanks STeve
ADB problems
I am getting the same issue under Linux. Under Windows the device is recognised and I can debug with ADB.
Good news. I found out how to get it to work. You need to add a file into /etc/udev/rules.d called 51-android.rules and in this file put the following: # usbboot protocol on FriendlyArm Tiny210 SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e22", MODE="0600", OWNER="<username>" Use the following to edit or create this. sudo gedit /etc/udev/rules.d/51-android.rules You can check the idVendor and idProduct using: sudo lsusb Hope this helps? Dave...
Hi Dave ! That's it !!!! Now it is recognized ! I did already have the 51-android.rules files and I did try a lot of combinations of udev rules, since it is used also for the other terminals, but this specific combinations of rules seems finally working on the board ! Thank you so much ! :) Now with the WiFI card working (simply great !) and the ADB working I have a nice dev platform ! If somebody else has similar issue, after editing the udev rule, the udev daemon must be restarted. Without rebooting the machine, on my Ubuntu 10.04 LTS : $sudo udevadm control --reload-rules Thanks again Dave, you made my day :) STeve
Glad to help Steve. Now all I need is an automatic 3G connection and I have a perfect platform to switch over from my old Netburner system. Still working on it. I can now dial from the debug port or from ADB but I would prefer if it would dial up automatically if there is a request for an internet connection :) Enjoy your new toy! :)
