I have a strange problem. When I run NK.BIN from Supervivi bootloader using [n] option, it boots correctly. However, when I load and run the *same* NK.BIN file (in RAM) from the YL2440AMON bootloader (on which, I guess, Supervivi is based), it boots to the point that ActiveSync connection is established correctly. However the display is lit up but blank. Strangely, I can view the device filesystem from my host machine. So I guess, the OS has booted correctly. The problem seems to be with the display driver configuration at boot time. However, I don't know if I can/need to pass any boot arguments to the WinCE kernel. Would appreciate any help/pointers to this problem. Thanks in advance. Gautam
WinCE 6.0 Boot Problem
Hi guys, I have a Problem trying to boot WinCE image. - I create SD boot card with uboot_movi... - I copy to nand STEPLDR_V0.1.nb1 - I copy to nand EBOOT_Q43_v0.1.nb0 - I boot from nand and press "Space" to access E-boot menu - in E- boot menu I press "9" to format and "b" to reserve the blocks. - I press "u" ... and choose the NK.bin image in the Q43 directory and get the following error: __________________________________________________________________________ Ethernet Boot Loader Configuration: 0) IP address: 192.168.1.6 1) Subnet mask: 255.255.255.0 2) DHCP: Disabled 3) Boot delay: 1 seconds 4) Reset to factory default configuration 5) Startup image: LAUNCH EXISTING 6) Program disk image into SmartMedia card: Enabled 7) Program DM9000A MAC address (10:23:45:67:89:AB) 8) KITL Configuration: ENABLED 9) Format Boot Media for BinFS A) Erase All Blocks B) Mark Bad Block at Reserved Block C) Clean Boot Option: FALSE D) Download image now E) Erase Reserved Block F) Low-level format the Smart Media card L) LAUNCH existing Boot Media image R) Read Configuration U) DOWNLOAD image now(USB) W) Write Configuration Right Now Enter your selection: u USB host is connected. Waiting a download. BL_IMAGE_TYPE_UNKNOWN WARNING: OEMMultiBINNotify: Invalid BIN region descriptor(s). +=OEMVerifyMemory+ dwStartAddr:0x0 dwLength:0x0 Don't support raw image !OEMVERIFYMEMORY: Invalid image ____________________________________________________________________- I tried with more than 5 different NK.bin different images and always got the same error. Thank you very much for your help.
perhaps you use USB Port--> Transmit-->NK.bin this is mistake.
use below menu for transfer NK.bin
(USB Port--> UBOOT -->NK.bin)
UBOOT
hi. i tried porting WinCE on mini6410 thru sd flasher. i followed all the instruction and installed it properly. all the LED indications were observed as they are stated in system installation pdf. But, as i switched S2 to NAND and reboot the system, a blank black screen appears i.e. no OS is loaded. plz help.
