I am using T35 2.6.32.2 kernel. When I boot using the Qtopia root file system, I am able to read from /dev/adc. However, when I use a custom Buildroot rootfs with the same kernel, this file is no longer visible. Do I manually have to create nodes or something?
/dev/adc in custom rootfs
The Buildroot FS has enabled SYS-Filesystem. The ADC file is located at /sys/devices/platform/s3c24xx-adc/s3c-hwmon/in0_input
Oddly enough, I'm missing /sys/devices/platform/s3c24xx-adc too. Will try out the Pengutronix BSP and post results here.
With Pegutronix you find the SYS Filesystem enabled. In Buildroot you maybe need to enable it. The file /dev/adc belongs to the driver included to Qtopia root filesystem. Good luck!
