Error : Permission denied when start up Android in Mini2440.
Dich Kieu
Am working on booting android 2.1 to the mini2440..using supervivi..
I could load kernel.. kernel s pointing to yaffs .. but couldn load..
asking for permission... i got this error.. just go thru last 10 lines..
repeatedly getting that error..I will be very thankful.. pls help me...
Copy linux kernel from 0x00060000 to 0x30008000, size = 0x00200000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock2 init=/linuxrc
console=ttySAC0"
MACH_TYPE = 1999
NOW, Booting Linux......
Uncompressing
done, booting the kernel.
Linux version 2.6.27 (root@zaheersheriff-laptop) (gcc version 4.3.2
(Sourcery G++ Lite 2008q3-72) ) #300 PREEMPT Sun Oct 24 13:18:34 IOT 2010
Machine: SMDK2440
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
MM: CPU does not support supersection mapping for 0x55000000000 at
0xf0d00000
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc
console=ttySAC0
irq: clearing subpending status 00000003
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00000000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57
console [ttySAC0] enabled
Memory: 64MB = 64MB total
Memory: 60340KB available (3756K code, 634K data, 116K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
net_namespace: 288 bytes
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
SCSI subsystem initialized
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
NTFS driver 2.1.29 [Flags: R/W DEBUG].
yaffs Oct 24 2010 13:21:47 Installing.
msgmni has been set to 117
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
s3c2410fb_set_par!
Console: switching to colour frame buffer device 30x20
adc  initialized
input: buttons as /devices/virtual/input/input0
buttons  initialized
leds  initialized
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
nbd: registered device at major 43
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
dm9000 Ethernet Driver, V1.31
Now use the default MAC address: 08:90:90:90:90:90
eth0: dm9000e at c4804000,c4806004 IRQ 51 MAC: c3954934 (friendly-arm)
usbcore: registered new interface driver zd1211rw
usbcore: registered new interface driver zd1201
Linux video capture interface: v2.00
Driver 'sd' needs updating - please use bus_type methods
s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V
8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 333 at 0x029a0000
Bad eraseblock 505 at 0x03f20000
Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00060000 : "supervivi"
0x00060000-0x00260000 : "Kernel"
0x00260000-0x40260000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 128MiB 3,3V
8-bit" -- size truncated to 0x7da0000
0x00000000-0x40000000 : "nand"
mtd: partition "nand" extends beyond the end of device "NAND 128MiB 3,3V
8-bit" -- size truncated to 0x8000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver appletouch
input: s3c2410 TouchScreen as /devices/virtual/input/input1
s3c2410 TouchScreen successfully loaded
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz).
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
TCP cubic registered
s3c2410-rtc s3c2410-rtc: setting system clock to 2010-10-24 14:34:25 UTC
(1287930865)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs: auto selecting yaffs2
block 315 is bad
block 487 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem).
Freeing init memory: 116K
ts_control_open!
ts_control_release!
init: cannot open '/initlogo.rle'
sh: can't access tty; job control turned off
/ # init: cannot execve('/system/bin/mediaserver'): Permission denied
init: cannot find '/system/bin/playmp3', disabling 'bootsound'
init: cannot execve('/system/bin/dbus-daemon'): Permission denied
init: cannot find '/system/etc/install-recovery.sh', disabling
'flash_recovery'
init: cannot execve('/system/bin/keystore'): Permission denied
warning: `rild' uses 32-bit capabilities (legacy support in use)
g_file_storage gadget-lun0: unable to open backing file:
/dev/block/mmcblk0p1
uccoder
Looks like your system partition is not mounted
Juergen Beisert
You should read the information the kernel gives you carefully:
You instruct the kernel to use a larger NAND device (I guess a 1 GiB type)
than available (available is 128 MiB). This must result into a broken root
filesystem and the errors you got.
