Hi there, on my mini2440 with linux i have a c++ application wich fetches data via RS232. I want to show these values on a homepage i wrote on the build in Webserver. My question is, how could i pass the values from c++ to the php? Also i want to write values from the Website to the c++. regards ones
display values on homepage
Have you tried taking the data via the RS232 and passing it to an environment variable? Then using your PHP class/program to fetch the environment variables than echo out?
