Hello, I have got a mini 2440 and I can't make it work I have connected the power I can see the red led is on but nothing happen. is there a jumper or something I need to change? I have notice that if I connect the USB A male to the computer I can see it works. but it doesn't recognize the device in the device manager (I have win7- X64) any help will be good Thanks ,
new user need to understand basic
hi, I'm linda and I'm new too. I thought this is some documentation for newbies like me and so came here curiously :) I hope some techie will read and help you out of this.
If you are the distro that came on the machine or on the DVD I don't think a PC is going to recognise it. Think the keyword to search for here is USB gadget. Try searching on the forum. I would suggest that you get the device working as it comes before you start re-compiling kernels etc. mini2440_manual.pdf Should be a good starting point as far as getting the basic machine working. With the NOR/NAND in the NAND position it should boot to Qtopia (an old windows manger)
Hi david, linda, The manual suggested by @davef is a good starting point. Since you are using Win 7 (x64), you will need a 64-bit driver for the DNW utility used to download binary files to the board. You can find it here: http://www.friendlyarm.net/forum/topic/261 Scroll down till you come to the link for the RAR file containing the driver installer. Hope that helps. Gautam
