Few days ago I received a beautiful Tiny210 SDK CAP7 board with Android 4.0.3 already flashed, for a project I'm working on (thread Android questions). With the help of Reggie, Charlie and a LOT of searching the net I was finally able to re-flah the board, since the original version of Android missed the Google play and had other problems (debug mode not working). I spent a lot of time fighting with the SD-flasher and preparing myriad of SD cards, from 2 Gb to 8 Gb. Finally I decided to test an "old" image instead the latest one (March 2013), at least to see if the SD card procedure was correct. And it was ! I was finally able to re-flash the Tiny210. The re-flashed version probably is still not OK, i.e. is not solving my original problems, but I have a new one now ! During the re-flashing process, on the LCD were present messages but with many "blurred" characters, probably because originally in Chinese. So I don't know if during the flashing procedure I do have to do choices. The end of the procedure is indicated by two beep and a kind of menu' in yellow with apparently two choices (1 and 2), but no button seems working so I don't know if I have to select something. Anyway, after the flashing is done, I set back the S2 switch on NAND and restart the board. It works, meaning that "something" was loaded, and a calibration utility is called. The utility says : FriendlyARM Enhanced calibration utility Touch crosshair to calibrate TouchDevice : /dev/touchscreen-1wire And a crosshair symbol appears in the top left corner. However NOTHING happens. I can touch the crosshair symbol or all around, nothing. I suspect the utility expects a resistive touchscreen, I have the capacitive one. So at the moment I have a bricked unit ! Any suggestion about how to do the calibration and continue ? And anybody tried to flash a Tiny210 SDK CAP7 with a March 2013 release of the Android 4.0.3 ? Many thanks !! STeve
Tiny210 SDK CAP7 problems
Hi Steve, ok, well, the cap touch screen does not need to use the calibration like the resistive does. All you need to do is put skipcali=y (it might be y or yes) in the commandline in the FriendlyARM.ini file when you burn the kernel to nand. btw. if you only want to burn the kernel and the commandline, you should be able to use # to comment out the other lines in the particular section you are burning to nand (android/linux/wince). There was an armworks wiki but it's down whilst they sort out a new home for it, otherwise I'd point you directly to those tutorials. In theory, you should be able to use the old kernel and superboot with an updated rootfs image. Could you give us some more information about the tiny210 that you have? There are a few versions of '210' boards, at least 3 different ones for the mini210S and at least 2 for the tiny210, can you identify the nand chip on the board? it will be a K9GA, K9GB or something else but get the full number please.
Hi Reggie Thanks ! I really hope to see the Wiki soon so to don't have to bother you. I did try your suggestion but is not working. Here the FrindlyARM.ini I'm using : #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action = Install OS =Android LCD-Mode = No LCD-Type = S70 LowFormat = No VerifyNandWrite = No CheckCRC32=No skipcali = y StatusType = Beeper | LED ################### Android 4.0.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android/zImage Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 Android-RootFs-InstallImage = Android/rootfs_android.img ################### Android 2.3.1 #################### #Android-BootLoader = Superboot210.bin #Android-Kernel = Android2.3.1/zImage #Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=s3c2410_serial0 #Android-RootFs-InstallImage = Android2.3.1/rootfs_android.img ################### Linux #################### Linux-BootLoader = Superboot210.bin Linux-Kernel = Linux/zImage Linux-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4.img ################### Windows CE6.0 #################### WindowsCE6-Bootloader = Superboot210.bin WindowsCE6-BootLogo = WindowsCE6\bootlogo.bmp WindowsCE6-InstallImage = WindowsCE6\NK.bin WindowsCE6-RunImage = WindowsCE6\NK.bin I tried different options : - Skipcali = Yes - skipcali = y - skipcali = yes I think the first one (Skipcali = Yes) should have the correct syntax since all the other commands are structured like that, but anyway nothing seems stopping the calibration utility. The Tiny210 NAND is a K9K8G08U0B. The PCB is a Version 1.2. In the September 2012 image I'm using, I noticed there is another FriendlyARM.ini file, with some chinese characters in the name. I did update also that one with the skipcali option, but nothing. Thanks Steve
You missed a vital bit, the skipcali=y should be in the commandline setting for the image type you are loading: Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=y ctp=2 That is all 1 line and that should do it. I forgot to mention that you need the ctp=2 bit as well, my bad. The K9K8G08U0B nand is a 1GB SLC nand chip, you should be able to use the Android/rootfs_android.img from the latest images dvd, the kernel itself should also be slc compatible, the only thing that I can think is wrong is that you need to use the superboot210.bin file from the same images dvd, you must also make sure that superboot210.bin file is in the images directory on the sd card too. The latest images dvd is by far and away the best version of android ICS that friendlyarm have made, some months after I wrote my tutorials, they put google play store into the images for us, they also added the 'x86' ethernet patch for android, which means we get to use all of the google apps via ethernet as well as wifi now too.
Hi Reggie ooops, I misunderstood where the skipcal should be placed :) Anyway, almost there :( It worked but something is still wrong. Now Android is loaded, the splash screen appears and after a while the usual Android system is loaded. However the touchscreen part is not working. I tried different images, the old ones, the new one, I tried to change the ctp value to 1 instead 2 but still no touch capability. Some PCB buttons are working, I can recall some menus but since the touch screen is not working I can not select anything. On a older thread I found somebody had to set cpt to 3 (it make sense) ctp=0 ==> N/A ctp=1 ==> 7" touch with GT80X touch controller ctp=2 ==> 4.3" touch with FT5306 touch controller ctp=3 ==> 7" touch with FT5406 touch controller but if I do that, the boot process is stopped just after some Chinese writing appears on the screen and the NAND is not reflashed. On my FriendlyARM.ini file it is selected the display type S70, it should be maybe something different ? Sure is not a 4.3 LCD display so ctp=2 should be wrong anyway. The ctp=1 is not working as well but at least is not make the boot freezing. How I can determine what LCD is mounted ? There are no labels and the display is in a black box. I "think" the latest images DVD is working but I have to use the Superbot210.bin of the old one. The Superboot210.bin of the latest image (March 2013) is not working at all. Thanks STeve
Ok, it SEEMS I was finally able to re-flash the board successfully !!! Here what I did (hopefully can help somebody else :) ) - I took a 2Gb SD card (probably it will work with other sizes) - I formatted low level in fat32 - on the Windows machine I copied TWO images directories, one from a DVD on September 2102 and one from the March 2013 (should be latest one) - with the SD-flasher utility I fuse the Superboot210.bin from the September 2012 image - then I copied in the SD card the September 2012 image directory - after the copy, in the SD card, I erased the Android and Linux directories under image - I copied the March 2013 Android and Linux directories - I edited the FriendlyARM.ini file and I set up the Android command line as : Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=y ctp=3 (note the ctp=3 !) I put the SD card in the board and rebooted with the S2 on SD card. The installation was successful. Then, after setting the S2 on NAND, I rebooted the board. Android started, however the touchscreen was still not working correctly, but it was working. Only a small portion of the left side was doing something when touched. I then connected a wireless USB keyboard/mouse to the USB port, it was recognized and I was able to select menu' in that way. After few minutes that I was going around with the keyboard, suddenly the screen started to work normally ! So it seems that after a while an internal calibration utility is activated. AFter that I was able to remove the USB keyboard and further boot retained the touchscreen capability. Now I have the latest Android 4.0.3 up with Google Play capability. Soon I'll start to see if now also Adb can recognize the board. Thanks Reggie for the help !!! C'ya Steve
I'll need to double check, can't look at mine right now but will do some time today, I've got a mini210S here with the slc nand, afaik, the nand driver source code that's actually in the kernel should be aware of the SLC nand, in fact, they all should be, so that all sounds sane but the superboot210.bin from the latest images dvd should work as well because of the newer mini210S boards having the 1GB slc nand on them. If it's supposed to work and it's not then we probably need to let friendlyarm know and they can fix it.
OK, here's the commandline string that my board uses: root=/dev/mtdblock4 rootfstype=yaffs2 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=yes ctp=2 lcd=S70 skipcali=yes and ctp=2 are definitely what I have used. This is a 4GB mlc nand board though, I'll double check on a 1GB slc board and get back to you.
I just opened brand new box for Tiny210v2 SDK CAP7 board with pre-installed Android and tried to boot but nothing showing on the LCD screen except some lines on blank screen. Before I try anything, I wanted to check if this supposedly pre-installed board works or not but nothing happens. I fused superboot SD card to boot from SD card to see if that makes any difference but no luck. No blinking on LED and blank LCD with rainbow colored lines. Anyone can explain if this Board is bad or if I am totally missing something. I am using Window 7 notebook with USB to RS232 with Hyperterminal. would appreciate your help. Seyul
When I received mine I just power up it and Android 4.0.3 was already installed and working. Actually my board arrived "ready to use", i.e. nothing to put together, so I suspect it was tested before the shipment. So yes, it is supposed to come "ready to use". It is possible maybe a connector moved during the shipment. Did you check all the connectors ? You have probably to take apart the display from the board in order to check the cables. If still nothing happens, you can try to re-flash it but is tricky. If you have the wrong version of the bootloader (read previouse messages in this thread) nothing will happen during the re-flash. If still nothing, maybe the board is bad. Oh ... mine is the Tiny210 not the v2 version. C'ya STeve
