Hi All. I am getting an error arm-linux-gcc command not found while i am giving command make zImage for mini2440. I have already given correct path as export PATH=$PATH:/opt/FriendlyArm/toolschain/4.4.3/bin. it shows correct path when i type echo $PATH but don't know what is the issue please help.
may be you forgot ~ ? is it really /opt/FriendlyArm/toolschain/4.4.3/bin ? is it possible that it's actually at ~/opt/FriendlyArm/toolschain/4.4.3/bin ? did you try to execute just "arm-linux-gcc" ?
find where it actually is and put that in the export PATH= command instead? Did you unpack the toolchain as root?
Check if you have installed the correct system libraries. Run the "ldd" command on the "/opt/FriendlyArm/toolschain/4.4.3/bin/arm-linux-gcc" executable and see what it tells you. I guess a 32 bit versus 64 bit issue.
Hi Sir,
        The previous issue has been resolved i was not unpacking toolchain
in root. But now i am getting error while i am making zImage as.
 include/linux/math64.h: In function 'div_u64_rem':
include/linux/math64.h:43: error: '__LINUX_ARM_ARCH__' undeclared (first
use in this function)
include/linux/math64.h:43: error: (Each undeclared identifier is reported
only once
include/linux/math64.h:43: error: for each function it appears in.)
In file included from /tmp/linux-2.6.32.2/arch/arm/include/asm/page.h:26,
                 from include/linux/mm_types.h:15,
                 from include/linux/sched.h:63,
                 from arch/arm/kernel/asm-offsets.c:13:
/tmp/linux-2.6.32.2/arch/arm/include/asm/glue.h:119:2: error: #error
Unknown data abort handler type
/tmp/linux-2.6.32.2/arch/arm/include/asm/glue.h:160:2: error: #error
Unknown prefetch abort handler type
In file included from include/linux/mm_types.h:15,
/tmp/linux-2.6.32.2/arch/arm/include/asm/page.h:116:2: error: #error
Unknown user operations model
make[1]: *** [arch/arm/kernel/asm-offsets.s] Error 1
make: *** [prepare0] Error 2
now why this error is there?
  Mohan Saini, could you please tell me how you solved that toolchain problem as you said in your last comment here. I am facing with same problem:arm-linux-gcc command not found. I may also say that i did not find such a file in the necessary place. So i eould be grateful if by anychance you could zip and mail me the folder that contains the -gcc xecutable file.
export ARCH=arm These are all relatively standard things that you might expect to set before cross compiling a kernel, they should be very simple to find via google. http://billforums.station51.net/viewtopic.php?f=4&t=20
Thanks,
i did it and
now i am getting a new error.
prateek@ubuntu:/host/xilinx_example/ZYNQ_TRD_HOME/u-boot-xlnx$ make
zynq_zc70xConfiguring for zynq_zc70x board...
make
make[1]: Entering directory
`/host/xilinx_example/ZYNQ_TRD_HOME/u-boot-xlnx'
Generating include/autoconf.mk
cc1: error: unrecognized command line option "-mno-unaligned-access"
cc1: error: unrecognized command line option "-fstack-usage"
Generating include/autoconf.mk.dep
make[1]: Leaving directory `/host/xilinx_example/ZYNQ_TRD_HOME/u-boot-xlnx'
arm-linux-gcc -DDO_DEPS_ONLY \
    -g  -Os   -fno-common -ffixed-r8 -msoft-float  -fno-strict-aliasing
-mno-unaligned-access -D__KERNEL__
-I/host/xilinx_example/ZYNQ_TRD_HOME/u-boot-xlnx/include -fno-builtin
-ffreestanding -nostdinc -isystem
/home/prateek/Downloads/opt/FriendlyARM/toolschain/4.4.3/bin/../lib/gcc/arm-none
-linux-gnueabi/4.4.3/include
-pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux
-march=armv7-a -mno-unaligned-access
-I/host/xilinx_example/ZYNQ_TRD_HOME/u-boot-xlnx/board/xilinx/common -Wall
-Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral
-Wno-format-security -fstack-usage   \
    -o lib/asm-offsets.s lib/asm-offsets.c -c -S
make[1]: *** [lib/asm-offsets.s] Error 1
make: *** [zynq_zc70x] Error 2
can anyone help me with this?
  There are so many things wrong with whatever it is you're trying to do. Try giving more information about what you're attempting. We've gone from compiling a kernel for the 2440 to compiling uboot (I think) for something else, a xilinx chip, at least that's what it looks like.
i was following this link http://www.wiki.xilinx.com/Zynq+Base+TRD+14.4 for setting up xilinx zynq board. when i got stuck with the linux kernel make directory (7th section of the link) while using this command $make ARCH=arm uImage while searching for that i came across this wiki page http://www.wiki.xilinx.com/Build+Kernel In this,under the heading linux for zynq ap soc make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage command prompted error of Ygcc being not found I searched and set the PATH for it correctly, and then when i tried 'make' i got this error prateek@ubuntu:/host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx$ make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s cc1: error: unrecognized command line option ‘-mlittle-endian’ cc1: error: unrecognized command line option ‘-mno-thumb-interwork’ kernel/bounds.c:1:0: error: unknown ABI (aapcs-linux) for -mabi= switch kernel/bounds.c:1:0: error: bad value (armv5t) for -march= switch make[1]: *** [kernel/bounds.s] Error 1 make: *** [prepare0] Error 2 while searching for this error i came across this video http://www.youtube.com/watch?v=wlXbeqtW0hI at 3:07 there is a set of instructions, for the command $make ARCH=arm uImage i got the error of arm-linux-gcc not found.which i posted it here. later,before your reply,i got a .tar.gz file containing those executables. so i cross-compiled that folder and set the path properly. then when i tried $make command,i got the error that i had just posted. does this make any sense now??
i am sorry,i have missed a part. after the Ygcc error when i set the path and tried make i got this error too prateek@ubuntu:/host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx$ make make[1]: Nothing to be done for `all'. make[1]: Nothing to be done for `relocs'. CHK include/linux/version.h CHK include/generated/utsrelease.h UPD include/generated/utsrelease.h CALL scripts/checksyscalls.sh CHK include/generated/compile.h SKIPPED include/generated/compile.h CC init/version.o LD init/built-in.o PASYMS arch/x86/realmode/rm/pasyms.h LDS arch/x86/realmode/rm/realmode.lds LD arch/x86/realmode/rm/realmode.elf RELOCS arch/x86/realmode/rm/realmode.relocs OBJCOPY arch/x86/realmode/rm/realmode.bin AS arch/x86/realmode/rmpiggy.o LD arch/x86/realmode/built-in.o VDSOSYM arch/x86/vdso/vdso32-int80-syms.lds VDSOSYM arch/x86/vdso/vdso32-sysenter-syms.lds VDSOSYM arch/x86/vdso/vdso32-syms.lds LD arch/x86/vdso/built-in.o LD arch/x86/built-in.o CC kernel/sys.o CC kernel/module.o CHK kernel/config_data.h LD kernel/built-in.o CC drivers/char/xilinx_devcfg.o drivers/char/xilinx_devcfg.c: In function ‘xdevcfg_reset_pl’: drivers/char/xilinx_devcfg.c:162:2: warning: passing argument 1 of ‘__readl’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:59:1: note: expected ‘const volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:162:2: warning: passing argument 2 of ‘__writel’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:67:1: note: expected ‘volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:164:2: warning: passing argument 1 of ‘__readl’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:59:1: note: expected ‘const volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:166:2: warning: passing argument 1 of ‘__readl’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:59:1: note: expected ‘const volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:166:2: warning: passing argument 2 of ‘__writel’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:67:1: note: expected ‘volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:168:2: warning: passing argument 1 of ‘__readl’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:59:1: note: expected ‘const volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:170:2: warning: passing argument 1 of ‘__readl’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:59:1: note: expected ‘const volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:170:2: warning: passing argument 2 of ‘__writel’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:67:1: note: expected ‘volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c:172:2: warning: passing argument 1 of ‘__readl’ makes pointer from integer without a cast [enabled by default] /host/xilinx_example/ZYNQ_TRD_HOME/linux-xlnx/arch/x86/include/asm/io.h:59:1: note: expected ‘const volatile void *’ but argument is of type ‘u32’ drivers/char/xilinx_devcfg.c: In function ‘xdevcfg_drv_probe’: drivers/char/xilinx_devcfg.c:1503:2: error: implicit declaration of function ‘of_get_next_parent’ [-Werror=implicit-function-declaration] drivers/char/xilinx_devcfg.c:1503:5: warning: assignment makes pointer from integer without a cast [enabled by default] drivers/char/xilinx_devcfg.c:1504:5: warning: assignment makes pointer from integer without a cast [enabled by default] cc1: some warnings being treated as errors make[2]: *** [drivers/char/xilinx_devcfg.o] Error 1 make[1]: *** [drivers/char] Error 2 make: *** [drivers] Error 2 it has something to do with xilinx_devcfg.c file. i have looked into that error with great detail and even tried out measures but with no avail.and hence i proceeded with the $make ARCh=arm UIMAGE_LOADADDR=0x8000 uImage command and proceeded with te error list
I just came across an error whose google results brought me to this page. when reported,one of the contributers asked to explain what exactly was i trying to do.hence i enumerated my problems,which has to deal with xilinx too.i am sorry,i am a newbie and hadnt really thought that i could just post FriendlyARM queries.i was just hoping for help here.
hai all, I have arm-linux-gcc-4.4.3.tgz and linux-2.6.32.2-mini2440_20110413.tgz. pc@pc-virtual-machine:~/arm/arm/linux-2.6.32.2$ make ARCH=arm CROSS_COMPILE=arm-linux-gcc menuconfig scripts/kconfig/mconf arch/arm/Kconfig *** End of Linux kernel configuration. *** Execute 'make' to build the kernel or try 'make help'. pc@pc-virtual-machine:~/arm/arm/linux-2.6.32.2$ make ARCH=arm CROSS_COMPILE=arm-linux-gcc make: arm-linux-gccgcc: Command not found CHK include/linux/version.h make[1]: `include/asm-arm/mach-types.h' is up to date. CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-arm CC kernel/bounds.s /bin/sh: 1: arm-linux-gccgcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 pc@pc-virtual-machine:~/arm/arm/linux-2.6.32.2$ i am getting this error,please tell me anyone how to install arm-linux-gcc and how to compile and build image for the above mentioned kernel.
Read the error message carefully: "arm-linux-gccgcc" :) Try with "CROSS_COMPILE=arm-linux-" instead.
I tried as you said it's compiled.For building image this is the command make ARCH=arm CROSS_COMPILE=arm-linux- zImage. I think there is a another method like export ? what is that method. Thanking you.
sorry sorry.. I am getting below error drivers/input/touchscreen/eeti_ts.c:64: error: implicit declaration of function 'irq_to_gpio' make[3]: *** [drivers/input/touchscreen/eeti_ts.o] Error 1 make[2]: *** [drivers/input/touchscreen] Error 2 make[1]: *** [drivers/input] Error 2 make: *** [drivers] Error 2 what is this error,how to solve it.
please tell me the process of cross compilation and building image for arm for kernel linux-2.6.32.2 with arm-linux-gcc.
Sorry, I only can help you with my own kernels for the Mini2440. I never worked with the linux-2.6.32.2 you mentioned.
I think kernel is not matter,the above process i mentioned is same for all linux kernels.please tell me about that process with any linux kernel with arm-linux-gcc cross compiler.I am using ubuntu 12.04 os.so please help.
> [...] the above process i mentioned is same for all linux kernels Your are right. The correct process for all kernels is to just fix the error.
It can be because you have not set the toolchain path to the bashrc file. I would suggest you follow this link: https://developer.ridgerun.com/wiki/index.php/Code_Sourcery_ARM_toolchai... Very briefly explained to install the toolchain to the required path along with all the dependecies.
