Hello I've been playing around with QtSerialport, but having some issues. Has anyone managed to get this going for a mini2440? Thanks in advance Ruben
QtSerialPort project
forgot to mention its for a mini2440. everything compiles when i set the build to desktop, but fails on target (QTest/QTest does not exist).
I use qextserialport in the Mini2440. I don't have any problems. See this: https://code.google.com/p/qextserialport/wiki/QextSerialPort_1_2_RC. You should then use option 1: "Usage(1):Source Code Only". Good Luck.
Hi Edison I also used qextserialport,until I discovered it reads the data inconsistently. it would read 11 bytes, the next read will be 8 and the next 3 bytes. Do you have a code snippet perhaps that I may use, maybe i'm doing something wrong. Thanks
Hi Ruben Sorry for the delay. See this post: http://theroomtech.blogspot.com/2013/06/mini2440-aplicacion-de-comunicac... I use this librarys and the application works without any problems. Good Luck!!!!!
Hi Edison thanks for the reply. maybe I should be a bit more specific. The device I'm interfacing with needs to be polled at 200ms intervals, if this is inaccurate then the device will not be initialized. this is basically what the problem is, i'm using qex and I compilled qtserialport last night and tested it on my host which is an i5, but the device is inconsistent and does not sync with my host. i'm using the QTimer and the above mentioned libraries. tonight i'll have a look at what exactly the response times are and the direction e.g. in/out. thank you for the link, will have a look at it. Ruben
Hi rky I followed this link http://qt-project.org/wiki/QtSerialPort, providing my qmake for mini2440 and copied the compiled lib into my project. Ruben
