I'm planning on purchasing one of these boards to use as a car pc, Is it possible to connect a battery pack to this board so that when the car is switched off it remains running for a set period of time and when on power it will charge the battery?
Tiny210v2 battery backup
Should be pretty straight-forward to do this. Do you only want to charge your external battery pack when the car is running? You can get or design a buck converter that will draw microamps after the battery charging cycle is finished. So, you could have the charger attached to the car all the time.
