I edit some file by using vi And reset board by using reset button or turn off and on. And then I check file what I changed. Sometimes it didn`t change. Maybe I think there is a delay to save. When reset immediately after save and quit, it didn`t change. Edit file and relax for a while and reset, it changed. Explain about this if you know.
Is there a delay saving files on Tiny 6410?
Sure. This delay is called "file cache" and improves the write speed in regular usecases drastically. But a "reset" is never a regular usecase, at least not, when the system is not down at this moment. Run the "sync" command after you have written back your changed file. Or - much better - unmount the filesystem prio reset (or re-mount it read only).
