Capacitive touch on ubuntu
Praveen
Hi Everyone,
I have tiny210v2, I have ported Ubuntu 12.04 LTS on it. It's 7" Capacitive
touch screen (S70) is not working. But when I port Qtopia touch works fine.
   I am also getting some data in (#cat /dev/input/event4) in Ubuntu but
cursor is not moving.Please help what to do.!!!
Praveen
voiconvuive
Have you installed tslib and linked qt to tslb library yet?
Kishor Dhanawade
Hello Pravin,
            Same problem with my Beaglebone black board and chipsee 7" LCD
with ubuntu 12.04 operating system. I am also getting some data in (#cat
/dev/input/event1). But on the GUI there is no cursor and touch is also not
working.If you find any solution please let me know. Thanking you.
Regards,
Kishor
Screwface
You need to use tslib to capture touchscreen events and map them to cursor
moves.
Maybe this can help you
http://www.ubuntuupdates.org/package/xorg-edgers/precise/main/base/xserv...
Regards
Kishor Dhanawade
      Thanks for quick reply. I installed tslib. Please, can you tell me
how to map touchscreen events to cursor moves. Thanking you.
Regards,
Kishor
WalterW
Please tell me how you managed to get ubuntu on your tiny210v2!!
There is a serious lack of documentation here on that, and no pre-built
stuff like there is for the others on the FTP/DVDs.
uelman
hello,
how do I put ubuntu 12.04 on my tiny210v2. Please I need help. The steps to
install ubuntu is not equal to install qtopia? where can I find a .img
ubuntu file equivalent to ''rootfs_qtopia_qt4.img''
Screwface
You can have a look at the near end of this post. Reggie has translated the
readme textfile using google.
http://www.friendlyarm.net/forum/topic/4708
@Kishor Dhanawade : I'm not sure it is possible to use capacitive
touchscreen with ubuntu. As far as I understood, tslib needs some kind of
"plugin" to acquire signal. Resistive one has been released as open source
by FriendlyARM if I'm right. But I've not seen anything for capacitive
plugin. So it is not actually possible to compile it with ubuntu toolchain.
But asking FriendlyARM, maybe they can give the source code ?
Reggie
it probably needs xf86 tslib driver.
WalterW
Reggie is that for the cap touch? (xf86 tslib)
Reggie
I searched for that but on debian it resolves to xserver-xorg-input-tslib
via a search on apt.
It still doesn't work for some reason, tbh I'm thinking about seeing if I
can make it work by the same hack as I used on the 1wire driver.
no need for all this hoop jumping just set it up as an event device.
